Swapping a t-56 in an auto LS swapped S14
Hello,
I'm thinking of buying a 240 that has an auto trans but it will be a road racing project so a manual is gonna be necessary I just wanna study cost and parts and make sure I'm not missing anything. New master cylinder, clutch line, trans, trans brace and ds. What else am I missing? I'll be doing all the labor |
the slave cylinder that mounts into the trans, a extended bleeder would be prefered because if you drop the 8mm socket into the trans you have to break it back apart.
you'll also need a flywheel and clutch kit
Looking for S14 1/4 window louvers! |
