#31 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
don't let the door hit you on the way out. the joke is the guy who thinks 230* water temps 'are ok because GM's run there. No wonder you're on your 2nd dealer as a 'tech' at your age...regular know it all I'm sure
![]() ![]() Quote:
However the stock gauge in the cluster is by no means anything you should ever trust beyond 'off, running, overheating' hahah.
#32 | |
I only pulled it back out because I had a problem that I didn't find until after I put in a Nissan thermo (a small leak behind the thermo housing). I never said it was junk, just that it has the 'blowoff' effect above 4000rpm. |
#33 | |
Trader Rating: (58)
#34 | |
![]() Join Date: Jan 2008
my stock gauge is actually reading colder( little below the middle.). which i think is interesting lol. but it make sense the water coming into the block is cold. i have dual mishimoto fans kicked on all the time. ( need to figure out the fan controller) when my old setup would over heat it was obvious on both gauges.
My Twin Scroll Gt30r Sr22det Build |
