#481 | |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
Yeah was going to run a HMIC but didn't want to relocate my oil cooler, 4 couplers is the way to go. Just have to make sure the holes in the bay are large enough to get the pipes out.
DLG - DIRTYLOVE |
#482 |
![]() Join Date: Jan 2010
so, the consensus is if you are drifting then you need to have tubs??
#483 |
![]() Join Date: Feb 2009
It helps with angle mods and wider wheels, yes. You will rub otherwise.
My Website | Unfriendly Garage | Endurance Motorsports | FitMyWheels - Fitment Calculator |
#488 |
Tubs!!!
Frame rail has never been an issue for me. Beat the hell out of those shelf bits and done. Firewall is total opposite. That's why I am doing tubs. Opens front section a ton allowing for more caster.
#489 |
![]() Join Date: Feb 2006
That makes sense. I guess its more so for guys using knuckles? I always rubbed the firewall. I hate running too much caster though. Makes steering too stiff.
#492 | |
I did it to remove rust, although now with more steering angle it has come in a bit handy, but one of my main foes for steering angle is that god damn tension rod, damn SPL and its beefy as shit tension rod haha
DLG - DIRTYLOVE |
#495 |
How low are you lol. 17x9 +12 rubs all over ImageUploadedByTapatalk1427731680.615205.jpg
#501 |
Coolant resivor tank sitting next to the wiper motor. That looks like a great choice for my setup (tubbed front end). Anyone make one? Most companies I have found just do the big cylinder style ones. Any info would be great.
#509 |
![]() Join Date: Apr 2010
In the process of tubbing the old s13 myself right now, the question I have is why are many people kind of "stepping up" the new flat sheet metal sections higher than the actual frame rails? The easy answer I guess would be for just that little additional clearance?
