bad alternator?
need help. car wont start without a jump. everything works. light,radio,windows. but car wont start on its own.. KADE BTW.
alternator? ![]() sooomeone |
![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
take off starter(be sure to disconnect battery first) take it to auto zone and theyll test your starters voltage and if you need one then buy one there problem soved
**CoUpe LOve** #3
Keep it simple
My S14 did this after sitting for months. Turned out to be corrosion on the battery terminals that caused the issue. I suggest starting with the simplest things first. Clean your battery connections.
Peace, JJ |
