Need Help ASAP! zilvia pls help me! wont start.
i drive a fastback kade-t25 5 spd manual trans.
i have an event this weekend and no one can seem to help. heres the deal, my car wont start but theres air, fuel, and oil. it cranks but dont start. theres also a clicking type of noise coming from the fuel rail area. i miss shifted from 4th-3rd but i was only going 40mph if that could be a problem. fuel pump feeds and theres new plugs in there. all intercooler piping is connected and secure. also to mention i am running a FMU (temporary). it smells like fuel when i crank too. please help me! any info and help will be greatly appreciated! THANKS in advance! |
also forgot to say i did "the ol' screwdriver spark test", grounded to the valve cover and the spark is white-ish orange.
i know thats bad but what does that mean? i know when you use a spark plug its supposed to be blue-ish. but idk about the screwdriver color. pls. i need my car asap. thank you. |
UPDATE:
just read the ecu and it reads the followinig: Idle Air Control Valve (idk why it reads but its good and secure hoses are straight and no leaks) Leaking injector (fakkk) HELP! and exhaust sensor (i dont care about this one.) |
![]() Join Date: Nov 2007
pull out your spark plugs and tell us what they look like or take pics of them.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
well i did another spark test on a working spark plug and it was orange-ish white. and the spark plug was wet when it was removed so im certain theres fuel..
some people told me maybe its my ignition module or timing but i need more opinions. and i have an event coming up, i had to miss the "test and tune" day. drift event is this sunday. help? ![]() ![]() ![]() |
