![]() Join Date: Dec 2010
S13 pbm max angle knuckle/lca on s14?
I picked up the pbm max angle knuckle and lca that came off an s13...I was wondering if I'm going to run into any issues installing this on my 97?
Also I was planning on picking up Megan inner tie rods and ends. Because from what vie found through searching this seems to be a necessity. Is this what I need? And will this work? Thanks for your help |
Running S13 Knuckles on an S14 is simple.
You'll need the matching ball joints for the knuckle, if the LCA is already for the knuckle, you're good. Otherwise, you'll need the correct mounting bolts or conversion sleeves or drill out the holes to go with the bolt size. S14 Strut Bolts are 14mm where as S13 are 12mm. |
