Old 05-07-2016, 12:39 PM   #6151
Black240Ct
Originally Posted by Mister.E View Post
Which mounts are you using?
similar to suspicious auto mounts, but mine are from ebay
http://www.ebay.com/itm/like/1816796...&ul_noapp=true
they sit the motor a little bit forward where i had to trim the lower oil pan to clear the oem sway bar, and still had clearance 300zx trans issues.
granted it would fit, but i want as much ground clearance as i can get.
Old 05-09-2016, 11:26 AM   #6152
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
2JZGTE Swapped S-Chassis thread
Yeah I just looked and I'm going to stick with the R154 and get a 4.6 rear end. My install is clean right now, but i can already tell that i will have to murder my tranny tunnel/firewall to get the adapter plate and CD009 smashed in there.
Here is how everything sits as of yesterday:
Sent from my iPhone
Old 05-09-2016, 04:57 PM   #6153
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Wow, that looks great man!!!
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 05-09-2016, 05:55 PM   #6154
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Thank you! I still have so much more to do but I'm hoping to have it running in the next few weeks. I still need to change out the fuel pump and make the lines and then finish up interior wiring along with a few other things.
Here is my build thread if you are interested:
#/f/showthread.php?t=614797
Old 05-13-2016, 06:54 PM   #6155
rswails
rswails is an unknown quantity at this point
What is best Altima e fans to get, and for what setup?
Current setup:
Koyo Sr20det nflo radiator
s14
2jzgte vvti stock twins
Want A/C after getting initial setup working decently.
I know stock twins setup is way different than going single ( lots more room with single ), so please keep in mind I am asking about stock twin setup for now. Should I go slim fan of some sort, or make room for the Altima fans? Read more below.
I have done a lot of research on cooling and wanted to ask you guys this. I have an S14 with 2jz GTE vvti swap. I kept stock twins, engine is far back as possible before rear twin hits firewall. I bought a 1997 altima e fan for $30, ( 4 blade / 5 blade ), and still isn't enough clearance. I'm wondering if I should cut my rad supports to push things back, or spend more money for less CFM and get something more slim...
***EDIT*** I did cut my upper rad support to make it fit. I had to cut about 2". Also trimmed the e fan shroud to make it fit my radiator.
The kicker is I want to leave condenser in for AC, ( which I will hook up completely later ). This leaves less room, and makes more heat, but still I want opinions from similar setups.
As info, 1997 Altima e fan thickness is 4.5", not slim at all, but the 4 pin harness is compatible with s14 stock e fan connector.
I appreciate any help. I'm so ready to get this f u cker on the road!
rswails is offline   Reply With Quote
Old 05-13-2016, 08:35 PM   #6156
NOLAGG
NOLAGG's Avatar
NOLAGG is an unknown quantity at this point
I have Oem 350z fans you could use which blow down houses lol
NOLAGG is offline   Reply With Quote
Old 05-13-2016, 10:32 PM   #6157
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
Current setup:
s14
I just replied to your email, sorry for the slow response.
I ran your exact setup in my 98 for almost two years. Working AC and all. Custom cut Altima fans, twin 5 blade mod and yes cut into the core support to make them fit. This pushes the condenser forward but there is still plenty of room. So much so that this year after going ProEFI and single I decided to add a pusher fan in front of the condenser (between the FMIC and condenser) and it triggers on with the AC switch from the ProEFI.
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 05-16-2016, 10:16 AM   #6158
rswails
Anyone know of a working FMIC intercooler kit for s14 2jzgte vvti with twins? I dont have easy access to weld custom bends.
My FMIC size is 2.5" O.D pipeing going in and out. I think that is how you measure it? The FMIC was setup for sr20det before so I have piping for that but doesn't look like it will help much.
I already have the air intake kit, just need hot pipe TO intercooler connection, and cold pipe to intake connection FROM the FMIC.
Old 05-16-2016, 10:45 AM   #6159
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
I would say it's very similar to the s13, the cold side can be just 2 90* bends and a few couplers. As far as the hot side goes I can't tell you exactly but you should be able to make the sr20 piping fit.
bova17 is offline   Reply With Quote
Old 05-16-2016, 03:36 PM   #6160
rswails
Very helpful pics bova17, quick question, if you have a stock hood, did your hood close with maf installed and everything else installed, with that setup?
Old 05-17-2016, 09:57 AM   #6161
bova17
bova17's Avatar
I am not sure if it closes since I still have not put it on lol
Old 05-18-2016, 10:28 PM   #6162
BlackZenkiS14
Went to the drag strip tonight in the drift car, had a little trouble with getting the boost level I wanted, couldnt make over 18psi, but I'm overall fairly happy with the results.
-Kyle
Old 05-22-2016, 12:02 PM   #6163
Black240Ct
heres how my 350z trans swap went. where it sits etc. i went with maverick motorsports kit, cd009 external slave, actclutch
ended up making the trans tunnel larger to make as much clearance as possible with the trans and ground
grossly mig'd some steel
exhaust and trans
Old 05-24-2016, 07:09 PM   #6164
Mister.E
Mister.E's Avatar
Trader Rating: (53)
So...1JZ in an S14 w/R154. Should i get a 4.625 or 4.636 gear set for my diff? Or is the difference between the two negligible?
Sent from my iPhone
Old 05-24-2016, 08:14 PM   #6165
articzap
articzap is an unknown quantity at this point
Sent from my iPhone
RPM...........4.625 Gear.4.636 Gear
8000 RPM 133.79 MPH 133.48 MPH
7500 RPM 125.43 MPH 125.13 MPH
7000 RPM 117.07 MPH 116.79 MPH
6500 RPM 108.71 MPH 108.45 MPH
6000 RPM 100.35 MPH 100.11 MPH
5500 RPM 91.98 MPH 91.77 MPH
5000 RPM 83.62 MPH 83.42 MPH
4500 RPM 75.26 MPH 75.08 MPH
4000 RPM 66.90 MPH 66.74 MPH
3500 RPM 58.54 MPH 58.40 MPH
3000 RPM 50.17 MPH 50.05 MPH
2500 RPM 41.81 MPH 41.71 MPH
2000 RPM 33.45 MPH 33.37 MPH
1500 RPM 25.09 MPH 25.03 MPH
1000 RPM 16.72 MPH 16.68 MPH
Math was done assuming 1:1 transmission ratio and 26" tire.
A burnout would make a bigger difference then difference between those two gear sets.
The real question is why do you want such a low gear. It's essentially useless.
articzap is offline   Reply With Quote
Old 05-24-2016, 08:58 PM   #6166
BlackZenkiS14
Love how this turned out. Looking for 11's this summer.
-Kyle
Old 05-25-2016, 07:47 AM   #6167
Mister.E
Mister.E's Avatar
Trader Rating: (53)
I was told that the gearing of the R154 is drastically different from the SR/KA/CD00A and that the 4.6 final gear was necessary to avoid having to drive at high RPM at low speeds, is that not true?
I'm a complete moron when it comes to gearing. Thanks for those numbers by the way!
Old 05-25-2016, 08:25 AM   #6168
articzap
Most people who JZ swap opt for Q45 diff's, which are 3.5-3.6 depending on year. The small the number, the taller the final drive, the less RPM you turn at highway speed, the more top speed you can get per each gear.
The higher number final drives are often used in very low power setups to keep RPM's high, and in the torque span of the engine.
Old 05-25-2016, 09:01 AM   #6169
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Damn, I'm a dweeb. Maybe a 3.6 would be best...I'm off to google to see if I can find a good gearing calculator, thanks for your help!
Old 05-25-2016, 11:01 AM   #6170
Black240Ct
i jsut sold my 4.36 i used for my SR and am going back to 4.08 for this motor set up. im sure the torque will be improved with a 1jz
Old 05-25-2016, 12:31 PM   #6171
Mister.E
Mister.E's Avatar
Trader Rating: (53)
I'm going to find a 3.5 or 3.6 and give that a try. I'm still going to keep the factory 4.083 just in case.
Old 05-28-2016, 11:05 PM   #6172
TJ_240
TJ_240's Avatar
TJ_240 is an unknown quantity at this point
How was your experiience with the W58?
Originally Posted by kaking View Post
I have a brand new Wiring Specialties harness I'm looking to get rid of. Figured I'd let you guys know first
Aristo 2jz
twin turbo
w58 trans
OEM ecu & OEM injectors
great option if you're staying OEM for a while.
PM or [email protected]
TJ_240 is offline   Reply With Quote
Old 05-31-2016, 09:16 AM   #6173
RaNMaN
RaNMaN is an unknown quantity at this point
I have a Q45 3.69 ring and pinion on an OBX helical differential in my original s14 diff housing. It was a lot of work to put together so I'm not going to just give it away but it goes together perfectly with the r154 and otherwise stock rear end.
I can't reuse any part of it with my new setup (3.13 pathfinder diff) so it's for sale. Message me if you're interested.
RaNMaN is offline   Reply With Quote
Old 05-31-2016, 09:54 AM   #6174
2stepGoesPowPow
2stepGoesPowPow's Avatar
2stepGoesPowPow is an unknown quantity at this point
Welp, had a good run. Now parting out my 717whp sil80. If anyone needs xcessive mount brackets/trans bracket, aluminum 1 pc driveshaft, r154 that needs a rebuild with shifter extension or wiring specialties harness for s13 with a haltech ecu pm me! Motor nfs.
Follow on Instagram For The Latest Imported Inventory!: @2JOHNZ_GTE
2stepGoesPowPow is offline   Reply With Quote
Old 05-31-2016, 10:11 AM   #6175
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Thanks but i already bought a 3.6. I already have a 2 way differential so all I need to do is have the holes enlarged to 13mm. It's really not all that much work.
Sent from my iPhone
Old 05-31-2016, 10:22 AM   #6176
NOLAGG
NOLAGG's Avatar
Why are yot parting it out?
Old 05-31-2016, 10:29 AM   #6177
RaNMaN
Sent from my iPhone
Yeah, but it's not exactly easy. I bought drill bits to do it myself but they didn't cut shit and I had to have a machine shop open them up. Then you have to set the new pinion height using a custom spacer and crush a new washer to the correct torque. The spacer needs to go to the other side of the diff and then set backlash. It might be easy to somebody that does this stuff everyday but I wouldn't call it easy to do right to the average joe.
Old 05-31-2016, 10:42 AM   #6178
2stepGoesPowPow
Dont feel like dumping the $2500+ to put my cd009 in this chassis. Ready to upgrade to a different car.
Old 06-02-2016, 04:25 PM   #6179
TJ_240
TJ_240's Avatar
Sad, did you ever considered the T56? that woul've been a way better upgrade than the cd009
Old 06-03-2016, 05:27 AM   #6180
fd94
fd94 is an unknown quantity at this point
1jz r154 s14 for sale located in Miami DL. Need it gone ASAP! #/f/showthread.php?t=630178
fd94 is offline   Reply With Quote
