i know theres a seat thread but its old. i want some fresh info. im 6'3 im looking for the lowest seating i can get..my question is what is the best seat and rail combo for 6'3 guys?
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Custom rail bolted to the floor.
Depending on how big you are, a Sparco Evo 2 or Evo 2 plus is probably a good choice. With either seat, none of the off-the-shelf rails/sliders work since they're too wide. |
![]() Join Date: Mar 2011
cobra seats make a seat extra tall and wide, I think its called imola pro gt check out there website
Cobra Seats |
im 6'2" i just got a bride zeta II with NAMS ultra low rails. looks like ill have some serious head room.
I've got a memory fab S58 seat with memory fab ultra low rails and I fit pretty good in my skyline with a sunroof. It sits me about 3 or 4 inches lower than stock. FYI I'm 6'2" and my head hit the roof with the stock seat, now I've got a bit of clearance but not enough to use a helmet.
While it sits low and works fine, I've had nothing but trouble dealing with memory fab so I wouldn't suggest buying anything by them. I believe the S58 is a knock off of the recaro SPG seat, and the rails look a lot like the driftworks rails. In my other skyline I've got a bride Zeta and some bride FG rails and it sits about an inch or so higher than the memory fab set up. The only reason I fit in the zeta set up is because my other skyline doesn't have a sunroof. |
It should be very similar for an S13. I've driven and sat in a every type of S13 (240s, 180s, silvias) and as far as head room goes it's pretty much identical to my skyline.
I am about right at 6'0" i have the same problem,i have the bride super low rails and a corbeau forza and i still dont have hardly any head room with my helmet on
if only i was a tad bit shorter |
![]() Join Date: Apr 2009
I'm 6'5" and use a Recaro SPG Pole Position and the Buddy Club rails.
In a few weeks I'll be cutting out the factory catalytic converter hump and welding brackets directly to the floor. |
![]() Join Date: Jun 2007
im 6'3" and have a Recaro pole position as well with bride super low rails and i have headroom with a helmet in my S13.
Built RB25 - RB The World - Vertex Everything @RBVertexRidge |
helpful info! Im 6'3" and recently looking at seats and this has been on my mind for a while
subscribed |
#20 |
I'm 6' tall I bought some eBay seat mounts and I have adjustable sparcos just the entry level ones and my seats hits the ceiling so I suggest custom mounts and a seat that ain't too tall
#22 |
![]() Join Date: Nov 2003
If you are slim, I'd reccomend a Bride Zeta III Sport. And a set of Bride FG rails. I have an abnormally long torso, (sit as tall as someone 6'3"ish) and thats the combo I have, its the only one I can fit in with a helmet, and I have a motorized sunroof in my S14.
-Kyle |
#23 | |
#24 |
![]() Join Date: Mar 2005
![]() ![]() ![]() Feedback Score: 2 reviews
Bumping up this thread. I am 6'2 and I am trying to mount my corbeau forza sport seat. Nothing I do can make this seat sit low enough. I tried buddy club rails, a combination of buddy club/stock rails. Doesn't seem that it is possible for me to retain seat sliders. I have to mount the seat to the floor. But then I run into the problem of that stupid floor hump that s14's have. Any one on here have pictures of custom bucket seats mounted to the floor with that floor hump flattened out?
Corndrift Blog |
#25 |
Kind of like the orange s14 above but just a better pic of the drivers floor area and how the seat is mounted.
Corndrift Blog |
#26 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
#29 |
The difference must be in the seat. I'm 6'5" and I'm running a bottom mount recaro srd with a bride ultra low rail. I have at least a couple inches above my head still and have no problem fitting.
#30 |
Trader Rating: (58)
That's nutty...that or your've simply got longer legs than he does etc etc
