#63 |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
Weatherstrip-body side, right-hand #76860-35F01
Weatherstrip-body side, left-hand #76861-35F01 Weatherstrip-front door, right-hand #80830-35F01 Weatherstrip-front door, left-hand #80831-35F01 Moulding set-windshield #72750-52F10 |
#64 |
Suspension Parts Updates
I know i have been posting a lot of parts and no work to the car since i did the interior coating. But i did make the stop into Enjuku Racing today to see my buddies Ant(240sx Parts Guru) and Brett (The 180 king lol) but i will promise you guys next week a lot of work is going down on the suspension front an rear this sunday when see the pic's below i cant wait to install these parts. wont be able to feel them on the road just but i know it will feel alot better then before.
New Rack and Pinion New Tien Hardened Inner Tie Rods to replace those weak stock ones New Circuit Sports Stg 2 Outter Tie Rods New Steering Column Bushing New Isis Front an Rear Sway bars with new Bushings New Circuit Sports Front and Rear Endlinks New Isis Traction Rods an Ruca's (I already have the toe arms in the rear and the tension rods in the front this was all that was left) Newer Cleaned Up subframe to put all this stuff on along with new energy suspension red bushing to replace the old ones im going to burn out
92' 180sx Type-X- (Under Construction) |
#67 |
![]() Join Date: Jan 2010
I expect a total tally when this is finished!!
#68 |
Andrew, you got a part number for the plastic trim at the bottom of the windshield that houses the wipers?
#69 |
Did ISIS only make the sway bars for up to 94? Cant find them anywhere for my 95 240....
***FortuneMinds*** 95 240SX S14 / 14 Lexus IS250/ IG / Twitter: juvi22003 |
#70 | |
Nissan does not produce that part anymore it is not available. so we can not get it
#71 |
![]() Join Date: Oct 2008
Trader Rating: (131)
Beautiful restoration here man- nice dedication to the details. It's impressive that you not only found all of those tough to find OEM parts, but you actually shelled out the cash to buy them.
Excited to see where this goes- very nice work! |
#72 |
Thank you !
#73 |
Thanks for the liking and appreciation for my build/restore. Hearing that from one of my favorite Type-x builder's is great motivation for me to get this thing done.
#75 |
Parts Install Updates
So i picked up all of the parts i needed to finish my front suspension and all the parts for my rear sub-frame to get started on it so i can drop my crappy original one out and replace it with all new bushing and suspension arms. Along with getting the rear knuckle bushings replaced for a better ride over all. And because i have it apart now i might as well do it since its all apart.
Here's a pic of my new rack installed with my cool gold isis sway bar and a picture of my tien inners an circuit sport outters on the new rack it all looks pretty good Now that i got the front completely done including installing a solid steering column bushing which is a real pain in the ass i wont ever be doing that again even if you pay me . I started on my rear subframe burning out the bushings and sanding it down and respraying it black.Burning the bushings (Stinky Stuff) New Poly bushings installed and subframe painted Then i had to drop my sub-frame in my car last time she see's the ground for awhile so i took a cool stance pick Then i pulled down the old one and stripped most of my good parts off Shot of the underside that i will be cleaning up and re-undercoating to give it that new look when i lift it up sometimes(hopefully never cuz everything will be new) And here she sits in the dark waiting for all the cool stuff that is gong to happen to her along with the new wheels coming soon and then the new heart RB ftw. I will have updates of the subframe install along with pictures of the under coating process i will be doing this sunday.
#76 |
Did you rattle can the subframe? I'm thinking of tackling that next on my car, but I was wondering if painting it with spray paint would be okay (for now).
#79 |
![]() Join Date: May 2008
Wow, what a build. Is this your original build thread? My guess is no and would love the link to the original
400HP KA24DET in progress
#80 | ||
Replies
This is actually my first build thread bro i did not really capture a lot from the first go round because i just had no intention to. But this time i was going all out and i wanted to share this awesome experience with the rest of my fellow zilvians on the block my throw some inspiration for some other crazy builds/restorations
#81 |
Great build. I too am anal when it comes to perfection on s13's. with that said do you have the part #'s for the switches (turn signal & wipers) those are clean!
your build is motivational! Thanks |
#84 |
Updates
So my goals these past couple of weekends were to get rear suspension completely assembled and installed. But i had to clean and undercoat the bottom of my car first well mainly the rear i already did the front. the undercoating was the dirtiest part of this build so far. but the results are amazing and so worth it to keep the bottom side from rusting.
Here is how the underside turned out Then i took my rear knuckles out to get the old bushings pushed out and have them powder coated black. And then install some cool poly bushings. They turned out great and Bretts grandfather owner of Yokleys Automoive Repair another 240sx guru helped me get these bushings pressed back in. If your in Clermont, FL you should check them out for any of your automotive needs great people work in that shop. After the knuckles were done i completely assembled my rear subframe with all my new parts. and it looked so good i didn't want to put it back in lol That same night i put it up but it was too dark to take pics. So the next day i went in and torqued down all the mounting points for the diff and installed my cleaned up BC coilovers and installed my Isis toe arms. An man can i say this thing it really solid i used to be able to move this thing a a little but everything is so tight and on point i cant wait to drive this thing an take through a turn. ![]() Here is a pic of it installed More cool parts came in like OEM shift boot Some steel braided Brake lines front for Z32's an stock rears I also picked up a sweet mint uncracked brown dash from a friend of mine Kevin who owns cool little cream s13 thats doing a crazy build on his car right now. and i know what you guys are thinking like BROWN WTF but im getting this thing professionally dyed black by my painter Clay the miracle worker Here is a picture before dye And after dye it looks so good and feel great to never knew i could do this but i was like damn this thing looks brand new after this While i was there a snapped a picture of this 240z he did a crazy paint job on that looks like glass not one wave or run or even orange peel it looks amazing check it out. Now this car is gonna be sick with its Rb25 single turbo it getting.
#86 |
Thanks bro you seem to be one of the few who really appreciate the quality of this build. Wait untill you see the parts update tonight of the crazy rare oem parts i got today bro. I just cleaned the shit out of it and wire wheeled all the little spots of rust under the car and scuffed most of it up with a 400 grit sand paper. and then degreased the CRAP out of it. let it dry for a day and then sprayed the undercoat
#87 |
![]() Join Date: Jan 2011
Holy shit man, car started out typical but turned around real fucking quick. I have a friend who works at Nissan so I'll be getting oem goodies through him now. I didn't know such parts were available. Your build is awesome man, love the oem way. I'm just indifferent about the RB only cause I'm afraid of them since I know nothing about them.
#89 | |
![]() Join Date: Apr 2008
Trader Rating: (161)
![]() Feedback Score: 161 reviews
