So its been almost 3 years since ive tooken apart my upper oil pan. Took numerous pictures and to the sequence, bolt size and thread pitch etc. But since then i have moved homes loss bolts and lost my phone that had all my pics and info.
Have searched webs and forms but all i have found is metric size for socket but not lengths. Iirc there were a couple different lengths. Im trying to figure them out and in which hole they goin. If anyone has any info please share. Thank you |
Guys, he asked what are the bolt size, not to buy a set of bolts. Buying a set of bolts leaves him $80-$100 less in the pocket and no where closer to what he needs............
I am taking apart a VE either later tonight. Hopefully the bolts are the same. If not, I will take a quick peak at the FSM and check back |
![]() Join Date: Dec 2013
if you want thread pitch they are all M8X1.25 sizes with the exception of the two nuts in the very back those are M6X1.00 |
Juan, that is NOT the question he asked...........
The bolts themselves have 3 different lengths. The OP is asking which bolts go where, not sell him some bolts..........Geeees! Atleast try to help the guy out I am looking at the FSM now and although they do not show actual lengths, there are three different lengths plus 1 nut. |
see attached picture, Triangle = Shortest bolts Star = Medium Length Bolts Circle = Two Longest bolts (should be obvious) X = Nuts & Washers. |
#8 | |
![]() Now, the OP can buy a set from you and also know where they all go . Good info Juan! |
#9 | |
Does anyone know or have this attachment? I had it but my phone reach storage capaitcy so I moved or possibly delete the file.
#10 | |
