Idle problem
Im posting this because my 91 hatchback idle was all jacked up going from 1100 to 600 at stop lights. I searched the forumns all over for a solution but everyone was convinced it had to do with the IAVC so i removed it, Still weird idle. So my buddy across the street came over and asked if i had replaced the distributor cap and rotor, tada that did it replaced both of them and the car runs at a smooth 750 no jumping whats so ever, so if you have a weird idle problem check these first!!!
KA, but my idle was fucked i mean i would have to hold my foot on the gas at lights so it didnt sounds retarded, but after i replaced the cap and rotor it was perfect. I still need to get lines and spark plugs but just the cap and rotor fixed mine doesnt even jump when idleing cold so try that i guess, then adjust the idle screw to the perfect purr.
#8 | |
![]() Join Date: Jan 2009
your problem almost sounds like mine, my SR idle surges up and down from 700-800, but it runs ok otherwise. sometimes it will drop to like 500, and other times it will idle at 1000 for a few seconds and th settle down to the 700-800 surge. Since yours was your destributer, im thinking mine could be the CAS. |
Took my car to the mechanic today and they got it down to 1100-1200rpms, but when i drove it away it went to 1400-1500rpms and it jumps up and down too.
Also when the idle went down, there was a noise in the engine now. When it was at 2k rpms, there was no noise. Any idea on what that noise could be? I want it to be around 800rpms. Can anyone show me where the idle screw is? I have a 93 240sx hatch Last edited by xpinoyxmk; 02-16-2009 at 04:09 PM.. |
