Ive been looking at converting my s13 to 5 lug and still keeping my abs. I was wondering if it was possible for the isis 5 lug hubs to have the abs ring pressed in them or compatible on the two front hubs
thanks. |
I have the Isis 5 lug as well and have the same problem as you. I think im going to press in my Oem bearings and try to have the Abs ring fitted on at a shop. SO if it works ill let you know.
![]() Join Date: Jan 2011
In case you missed my reply in the other thread, the S13 ABS rings can be pressed on the Contano 5-lug hubs. I have them on my daily driver for over a year.
After searching, I suspect that many of the aftermarket S13 5-lug hubs come from the same factory so most will be similar. I have a feeling that the ABS rings will fit on Isis hubs as well, but you're going to have to wait till Seathony confirms that. |
