Breakin process for new turbo?
Is there any break in process for a new/rebuilt turbo? from besides letting it idle for nurmerous min.
93 h/b. ka24de-t3(14), enthapy controlled .20bore, weistco 8.5.1cr, gReddy FMIC, E/L mani,t3 turbo to a 3in D/P to a HKS(88mm)HiPower and for cool sound effects the oldskool HKS Superblow, and you ask what about fuel? let me tell you 580cc, yes i said 580cc's, act clutch/flywheel. Buy my Coolio trading cardz! |
#4 | |
if someone did they deserve what they got, plus should recieve a kick in the balls for doing so
If you just bolted on the turbo for the first time:
Before starting the motor, it is important to get an adequate supply of oil through the turbo. To do this, disable the ignition or injectors (different for various cars) so the car is able to crank without firing. Crank the motor over for 30-45 seconds in 10 second intervals. This will pre-oil the turbo, and prevent premature thrust bearing failure. -fp |
#8 | |
![]() Join Date: Aug 2004
Pushing 14.7 PSI of all natural boost!!! |
or on the same line i would just pour oil into the inlet by hand, no reason to go that far for something i can do with the two hands, the two hands that my savior david, has given me
