![]() Join Date: Jan 2008
SR20DET engine start help.. Has spark & fuel but no start
Hey everyone. Only making this post because I have tried everything and have search and read hours worth of research.. Going to give as much detail as possible to hopefully narrow down what problem may be..
Also this swap is from a running car I had previously.. What's it doing: Car turns over fine.. Fire up for maybe 5 seconds and dies off.. Will run for a few seconds with starter fuel.. Everything I have done and tested: Checked all four plugs for spark and we have spark Checked injectors if they are all firing.. Took the fuel rail off with injectors still on to see if they sparying and they are all sparying but seem kinda weak (not sure how hard they suppose to spray but def sparying.. Checked the red wire from grey plug and red wire from injector harness for constant 12V and it's good Checked fuel pump pressure and it's 30-40 when prime and also when it's turning over Checked cas timing base off FRSport writeup and it's looks to be on point Checked all the ground from the intake, head, harness, ecu, injector grounds Checked mafs, all vacuum holes for leaks Checked IACV Checked all fuses Tired turning it over a few times with coil packs unplug to try flood engine and re plug coil pack and would fire up for few seconds and try to restart and won't fire up again I did cut off a few unnecessary plugs like for cruise control and wiper motor Have not checked compression but seems to be strong when turning by hand when putting tdc and also since it was from a running car List of mods: Red top SR20 550cc Power FC (previously tuned) Greddy intake Aftermarket exhaust mani T28 Walbor Fuel pump Adjust FPR Z32 mafs Any help, tips or suggestions highly appreciated..
Exclusive Auto Garage |
Alright so update.. Talked to my buddy Carl H and he suggested it may be a clogged fuel pump or sticky injectors. I know I had good fuel pressure so I went and rigged a pressure system to hooked onto fuel rail to clean them out with carb cleaner (having it spray into paper and not into engine of course). And after that it fired up! Considering the chassis had been sitting for await and had some bad/old gas it may have clogged the injectors..
