![]() Join Date: May 2003
Ooohhh...I know. Pick me!...I know!!!
It's the OBD II crank position sensor, used only by the ECU to help determine misfire (cylinder location). If you're putting that into an S13, then remove it. You can trash it if it's going into an S14 as well, with the only bad part being a CEL. Do I get a cookie? - Brian |
is that the vent, I cant even tell when I save and open up to zoom, too grainy, shit
ok thats why I dont know, its for an s14 ^^^^good job u should get a cookie
I was going to, but I can not think of a sig less than 75 characters. |
