Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 08-26-2011, 12:41 PM   #1
ZMan
ZMan's Avatar
ZMan is an unknown quantity at this point
DIY Article: Replacing the Engine Coolant Temperature Sensor on a '93 300ZX
Hello Z-heads,
I just replaced the engine coolant temperature sensor on a '93 300ZX TT and I thought that someone on this board would prosper from a nifty write-up on the job Let's get started!
Where is the ECT?
The Engine Coolant Temperature (ECT) Sensor is located in the front of the engine, in the top of the water inlet housing. It is Part Code 2630 in this diagram
Get to the removal and installation already!
1) Disconnect the Engine Coolant Temperature (ECT) Sensor wiring harness.
2) Remove the ECT sensor.
3) Replace the sensor with a new one.
4) Re-connect the ECT sensor to the wiring harness.
5) You're done!
As you can tell, it's an easy job that can be performed in a matter of minutes. Good luck guys!
ZMan is offline   Reply With Quote
