ac help sr20 swap
i have a video on how to to do the wiring for the swap but its with no ac. can anyone give me a link or advice on how to wire in the ac? thanks.
![]() Join Date: Jan 2007
s13: blue/green from the dash plug by the glove box, to the green/yellow main harness plug by the battery tray.
the ground signal from the request will click over the ac relay giving power to your compressor......i would also recommend wiring up the fast idle control device (FICD) so your idle doesn't drop too low when the compressor's on. run a jumper wire from your ac compressor's blue/red to your FICD 4 pin grey plug's blue/red to accomplish this. Dave |
| 240sx, air conditioning, hatchback, sr20det, wiring |
