Silvia with NRG seats
So I have seen some post about NRG seats and figured I would post on the install of mine. I'm running Planted seat brackets I picked up on Amazon(BTW they fit like s14 seats so I that fourth hole in the back by the door is a pain to get to fit correctly). The seats aren't bad for the price. And for our wider tuners they would work great! The problem with my setup though is that Planted seat brackets sit super high! Does any one know of super low well fitting seat brackets? uploadfromtaptalk1441676872734.jpg
Sent from my 202F using Tapatalk |
![]() Join Date: Aug 2011
I am using buddyclub sidemounts, they are available on frsports. They lock on each rail and have various brackets to accomodate any seat.
I have only 1 complain about them; the command to unlock the sliding mechanism needs to be bent to clear the front reinforcement in the chassis, under the seat, if you want to set the seat to the lowest possible setting (which is only a slightly bit lower than where the oem seat sits). You need to chose your seat carefully too; it need to fit between the rails, so no XL stuff. |
