Serious help... SR into a 200sx"ca18det"
Ok guyz ...
I own a gray 200sx s13 euro spec that came originally with a ca18det ...
I swapped an sr20det one year ago but kept the ca18's wiring and ecu !
Just changed the cas plug and injector plugs and the car ran fine for about a 1 year ..The reason i kept the ca18's wiring was cause i couldn't source out an sr20det wiring at that time...
anywayz..I got the sr20det wiring with a #62 ecu now...everything is wired up properly...But i can't seem to wire the 10 wires that go from the sr20det harness to the ca's "200sx" chassis wiring...
Did anyone do an sr20det on a 200sx "eurospec" swap ? where can i find a write up about it...all i found was at srswap.com but that's sr20det on a 240sx that came with a ka24de, but it seems that the chassis wiring differ although the colors are similar ...
