#91 |
So I got an SR Nismotronics ecu,
MRP Manufacturing Last edited by KAT-PWR; 01-12-2017 at 07:09 AM.. |
#92 |
![]() Join Date: Feb 2012
Trader Rating: (31)
Damn son I just went through all this. Crazy seeing we pretty much did the same shit going top to bottom lol. I have the ED fenders too (my alignment thread) my tires are just too damn fat for my car. I can't believe I just saw all this
#93 |
Getting antsy, waiting on SR harness. Intake is all done. Hoping to roll on the dyno by thanksgiving
MRP Manufacturing |
#94 |
Got my coil pack bracket
MRP Manufacturing |
#95 |
Been working on my wiring harness....
Also made these sheets for connectors/wiring All references looking into connector, push tab up,, read from left to right.
MRP Manufacturing Last edited by KAT-PWR; 10-23-2016 at 04:22 PM.. |
#96 |
Finally found the right size belt for the sr pullies. Tight fit. Almost done with the harness, intake is done. Should be able to start up with nismotronics very soon
MRP Manufacturing Last edited by KAT-PWR; 11-02-2016 at 09:37 AM.. |
#98 | |
Let me tell you it was way harder than expected to find just the disc. Managed to get one for $12. Would've hated to buy a good sr cas just to pull the disc out of rendering the sr cas almost useless for people needing one
MRP Manufacturing Last edited by KAT-PWR; 01-12-2017 at 07:10 AM.. |
#99 |
![]() Join Date: Mar 2009
Hmm, kind of surprising since everyone that runs AEM s2 ems uses the AEM trigger disc. Which you probably could have used too if you went that route.
#101 | ||
I bought the bracket from KED-BMX
MRP Manufacturing |
#102 |
MRP Manufacturing |
#104 |
After a year to find some
Mounted, should have hood on tomorrow
MRP Manufacturing |
#106 | |
I'm currently taking 19 credit hours to finish my bachelors and I live 1:45 away from the car. Harness is about done.Only need to run wiring to the ECU boost solenoid and we'll be ready to get rolling.
MRP Manufacturing |
#107 |
Finals next week, then I'll be home with the car and it will be tune time. My roommate whipped up this cas cover for me to print
MRP Manufacturing |
#109 |
Central florida, should be going to UF for my DPT If it all pans out
MRP Manufacturing |
#110 |
MRP Manufacturing Last edited by KAT-PWR; 12-23-2016 at 12:00 PM.. |
#113 |
Been driving the car everyday. Base map is tits, rich when the meth comes in which is to be expected. Put a thermostat back in it, coolant flush, fixed my fans. Had to replace leaking turbo feed fitting. Car feels really strong and it's only on 12psi spring. Diff is noisy but ohh well.
Played with the idle recovery in the software wow Nismotronics is so easy to use. Going to datalog and adjust tune to minimize Dyno time. Worried about her mechanics dialed in so the car has been aeroless for now
MRP Manufacturing |
#115 |
Better designed SR you mean
Basically I robbed the SR parts that are worthwhile (coilpack capability, pullies, cas, intake manifold, iacv) and scrapped all the bad stuff ![]()
MRP Manufacturing |
#117 | |
Mine has been completely rewelded and braced Relief cut the flange
MRP Manufacturing |
#118 |
200 miles down on the set up. Plugs look good. Car pulls great on 12psi, almost ready to turn it up to 25psi
Did a leak down test for the fuck of it. At least 10k miles boosted so far. 5% on all cylinders. Happy with that.
MRP Manufacturing |
#120 |
Wrecked my bumper on a root in my friends driveway
MRP Manufacturing |
