#32 |
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
As long as MSRP remains the same our price will as well! We ship worldwide 5 days a week
.Regards, Robert
940-683-8282 x20 Robert Del Angel CLICK HERE FOR OUR FACEBOOK PAGE!!! FOLLOW US ON TWITTER!!! Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!! |
#40 |
The turbos advertised are the new line they are introducing. None of the other turbos have dropped in price. As stated these are Journal bearing turbos hence the MUCH lower cost. Personally I do not mind a journal bearing turbo as with a turbo in t25 flange you will not see a huge difference in spool time. Now when you to T3 and larger then yes ball bearing is must.
Regards, Robert
#44 |
These are direct bolt on systems sir!! Nothing else needed other than your obvious supporting mods(fuel, fmic, tuning software)
Regards, Robert
#46 |
All that ordered have shipped out. No dyno's as of yet sir.
Regards, Robert
#49 |
Not as of yet sir! Haven't done any installs here at MVP thus far.
Regards, Robert
#51 |
Would of been me but I'm getting married in two weeks so all my dollars just went poof...lol
Regards, Robert
#52 |
![]() Join Date: Dec 2006
id really like to see how these stack up to the Greddy/ Trust 18g and 20gs. These seem to be similar target hp levels for those turbo, both of which are journal bearing. Lots of guys are running them over in Japan, and love how quick the spool is for the power they can put down. It would be a real treat to see how they would pare up, then do a split and compare them with 2860 and the 2871/6.
#56 |
No sir not as of yet. The only update I have received was from a customer in Australia that made 46x on the 8270 on his S15(built 2.2 stroker).
Regards, Robert
#57 |
Dyno sheet for you guys from my personal car running the M8270. Runs were done in 115 degree shop temps, 13x degree intake temps, this was the last pull of the day after being on the dyno for 4+ hrs.
23 PSI/C16/8 degrees of timing/11.8 AFR'S/Tuned on AEM V1 - Maximum reliability hence no timing really at all and conservative AFR's. Overall I'm EXTREMELY happy with the car. Just waiting on some cooler temps to redyno as it was hot as hell on the day we were tuning. On pump gas it put down 394 at 17psi on the same day/same timing/11.1 AFR'S. Dyno from the other night. It was about 93 degrees outside vs 115 of the above dyno so much cooler than what we have seen this summer. Boost was at 20 psi vs 23(profec was acting odd and cutting boost back at 20 vs 23 like it should. Regards, Robert
#58 |
Video on the dyno from a cooler night, around 91-93 degrees(when you are used to 110+ this night was cold lol) if I remember right. Mid range picked up a ton but my Boost controller was acting funny and would only hit 20 psi then stop. Peak power was down 10 rwhp but the mid range torque and hp went up a good bit. Was at the drag strip for 5 hours then 45 min drive back to the shop. Threw it on the dyno without any sort of cool down.
http://www.youtube.com/watch?v=rIsJv47_-Cc Regards, Robert
