![]() Join Date: Dec 2007
I was driving the sr 2day and i hit a driveway with my front mount.. i
parked it right after. then i started it up after i got off work and it started sputtering all crazy... wont idle and black smoke. i checked for the front mount and there is a big ass hole where the cold pipe and fmic go together. could a hole fuck it up that bad? my guess is because it doesnt have compression so the ECU gives more provides more fuel. what do u think? i drove it home bogn at like 1.5 grand all the way.. ANY HELP WOULD BE GREAT!!! thanks -steve |
Man w/ CTSV & a Car Seat
To explain whats going on, your maf measures the air going into the system. That signal is used by the ECU to figure out how much fuel to put into the engine. Since you have a giant leak, all that metered air isnt going into the engine, causing it to run REAAAAAALLY rich. Thats why its sputtering and smoking. Plug up the leak and it should run fine. Just dont boost till you fix it properly.
