Old 09-20-2015, 11:24 PM   #1
kouki_drifter
kouki_drifter's Avatar
kouki_drifter is an unknown quantity at this point
s14 sr20 fully built for sale and many accesories
I'll start top to bottom
Ngk level 7 plugs
New oem lifters
New oem rocker arms
Hks ras
Hks step 1 256 cams
New cam sprocket
Arp head n main studs
3 angle valve job
New valve seals
Port n polish
Gasket match
Decked the head
Apexi multilayer head gasket
New timing chain kit (chain guides tensioner sprockets gaskets)
New oil pump
New oil pump drive gear
Nismo 65C thermostat
Wiseco 86mm piston heads
Eagle H-beam rods
Acl main n rod bearings
Full gasket kit
Greddy oil pan
Tomei expreme header
New O2 sensor
New oil pressure sensor
Tomei turbo elbow
Oem filter
Arp fly wheel bolts
Atc 6 puck clutch
Nismo motor n tranny mount
Braided turbo lines
Greddy magnetic oil plug
aline hone
I think that's all of it I might have missed a few things but I'm right at about $7500 more or less
here is the link to the build #/f/showthread.php?t=415523&page=2
i have new turbo and intercooler and much more text me if interested
(505)718-nine2six9
kouki_drifter is offline   Reply With Quote
240sx, kouki, motor, s14, sr20
