![]() Join Date: Mar 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
Sr20 Act HD Clutch, Mazworx Headstuds, SR20 Stuff
Shippin available at buyers expense + paypal fees. Unless stated.
Price reduced....... [B]I will only TRADE for: Vertex or Cwest Wing, S14 fender brace, S14 Cf trunk, Defi Din Gauges kouki cf cooling panel ------------------ PICS SOON......] S14 Sr20 VTC Sensor- Best Offer Sr20 Knock Sensor- BEST OFFER SR20 NGK 4x BNIB Spark plugs- Best offer Sr20 Clutch Fan- 50 S14 SR20 Oem Shroud & Fan- 75 + Shipping Ka speed sensor (Fix speedo on SR swaps,great shape)- Best offer Sr20 Transmission Dust Plate- 50 S14 5 Speed Crossmember (Mint Shape)-65 shipped Z32 Rear Aluminum Spindles- 55 Pickup /70 shipped --------------- Sr20 Act HD street Clutch 5 miles -345 Shipped / Add $100 Flywheel (5 miles on New Resurfaced) s14 Zenki Sr20 Ac comp + Cody Ace Ac kit, Belt not in pic but included (powder coated)190 Shipped S14 Sr20 Intake (Polished) manifold, Polished TB, New TB Bolts & Gasket, Powder Coated Tubes- Best Offer Iacv & TPS Not included. Sr20 Motor mount Brackets (Freshly Powder coated! Eggshell Black)-40 each 75 Both SR20 Starter (Painted clean! Low miles)-125 shipped S14 Sr20 Water Inlet (Tapped for temp sensor, earls fitting / Grommet new)- SoLD S14 signal/Headlight switch (swapped for se)-SOLD SR20 coil packs 4(low miles)-115 shipped BMC HeatSheild (I manage to use this for s14 but I think made for S13)- 30 shipped S14 (came of clip 40,000 miles)oem jdm fr Swaybar with endlinks + New Energy sway bushings & Bracket- 60 Mazwork Sr20 Head Bolts- SOLD Condition: Been torqued down Once only. Super Clean SHape. Nothing striped, Took close ups so u can see Better. Sr20 Shifter with OEM Rubber- 50 shipped JDM s14 climate Bezel w Card Holder- 100 shipped!! $$Drop S14 Dust Sheilds- 7 each[/QUOTE] [B]S14 Sr20 Oem oil sender block (No sensor)- 40 Shipped S14 4 LUG HUBS (REARS ONLY)=30 S14 BALLER BOLTS Fr Strut bolts- 20 shipped Slave Cylinder Low miles- 25 shipped FR. S14 brake calipers and lines (NO ROTORS)-40 Oem S14 Radiator Cool panels (Don't know exact name)-25 shipped! S14 tension rods-15 S14 RHD ABS unit & abs lines- 90 S14 rhd jdm A/C High side line-10 RHD S14 air ducts (Under dash)-7 each S14 Battery/Ground wire- 7 each Last edited by Relentless240; 08-22-2015 at 09:27 PM.. |
