S13 SR20 Timing Chain
Hey guys,
I just replaced my timing chain on my S13 SR20DET and I was hoping some of you could verify I did it correctly, that is, before I put my new oil pump / timing cover on. Oh, and I know I have the wrong bolt on the right timing guide. I'm waiting for the correct one to come in. Here are the pictures. http://i82.photobucket.com/albums/j2...M744/004-1.jpg http://i82.photobucket.com/albums/j2...M744/005-1.jpg http://i82.photobucket.com/albums/j2...M744/007-2.jpg http://i82.photobucket.com/albums/j2...M744/008-1.jpg I was also curious... when turning the engine over, will there be periods in the cycle were the chain has a little bit of slack? Like in this picture. http://i82.photobucket.com/albums/j2...M744/002-1.jpg Thanks! |
![]() Join Date: Nov 2010
![]() ![]() Feedback Score: 12 reviews
just put my motor back together and looks just like it so your set, as far as the slack i think just a littleee. thats what the tensioners for. just remember to set the cas right, i may take a few times to get it in right
![]() Join Date: Dec 2003
Looks right to me... Are the #1 I/E cam lobes apposing? There shouldn't be any loose spots like that as long as you're rotating the crank in the CW direction (as you look at it from the front). Make sure the "arm" has released on the tensioner, I've had to use a long screw driver to release it before. If it makes you feel any better, here is a picture of mine after reassembly.
Everything looks good... Just a suggestion, remove that upper timing chain guide. Later model engines omitted that guide completely.
My SR20VET |
