Located in 33426 FL
Willing to work out combo deals, or part certain things out Bare with me ill be updating this with prices/more parts daily Defi EGT/Boost gauges $SOLD$ shipped ![]() ![]() ![]() S13 trunk latch full assembly $50 ![]() S13 FLCAs with refillable balljoints ($100) ![]() ![]() ![]() ![]() S14 Throttle cable $40 ![]() ![]() S14 trunk cable $30 ![]() S14 Mint fusebox and whatever harness is left/plug $100 ![]() ![]() ![]() ![]() Whatever these are, $30 each, off a S14 98 ![]() ![]() ![]() ![]() S14 ones, $60 ![]() ![]() Off a s14 mint one $30 ![]() ![]() S14 98 automatic handbrake assembly so its super mint and barely used, cables are not stretched what so ever, $SOLD$ shipped (auto/manual same shit i just mentioned auto since its never used in auto cars so the cables are not stretched or used up) ![]() ![]() ![]() ![]() Cusco S13 front t arms straight from japan $SOLD the shits are not seized move freely and nicely ![]() GT3071R Twin Scroll MINT turbo $SOLD$ with 4' inlet pipe and coupler, and turbo back pipe with 2 AEM sidebands Fullrace twin scroll manifold $SOLD$ this shit aint cheap Tial wastegates $SOLD$ each still new just installed,$SOLD$ for both with dump tubes Or buy complete turbo kit for $$SOLD$ (turbo, wastegates, dump tubes, manifold, new oem gasket, turbo blanket, 4' pipe, 2 aem wideband sensors and turbo back pipe,an fittings/lines to sr block heat wrapped and stuff and more!) ![]() ![]() ![]() ![]() B&M New shifter $SOLDjust installed never used ![]() Greddy pulleys $SOLD$ ![]() Greddy real intake manifold with rail and new gasket $SOLD$ ![]() S13 sr20det oem fmic pipings $100 ![]() Denso 550CC injectors $$SOLD$shipped ![]() ![]() Nismo slave and line (new) $$SOLD$ ![]() ![]() Off a s13 $SOLD ![]() Front and rear powder coated calipers with rebuilt kit $$SOLD$ ![]() ![]() Apexi M1 Exhaust just wear from being stored but new practically $$SOLD$ ![]() ![]() Tomei Oil Pan $$SOLD$new just installed ![]() MFLOW DOWNPIPE w/ flex $$SOLD$ ![]() $SOLD$ SR20DET S13 MINTY AF looks like its got less than 100kM and never been cracked open, its silver as can get inside what I can see from the valve cover and oil pan taken off Comes with wiring harness wired to S13 transmission and stage 3 act clutch drive shaft Nismo new mounts all around alt, ps pump, belts s14 waterneck new sensors lots of goodies i can work a deal with most of the stuff on it or without I don't mind selling the engine without the intake/turbo kit or mixing and matching, this swap is clean as hell. ![]() ![]() Cusco coilovers $500(fronts are on the car used to roll it around currently but have all 4) ![]() Last edited by Nissan2nr22; 07-01-2016 at 12:02 PM.. |
