Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Administration > Forum Suggestions & Technical Support
Forum Suggestions & Technical Support Post any suggestions or questions related to this site.
Closed Thread
Old 10-01-2013, 04:11 AM   #1
SXIIIkali
SXIIIkali is an unknown quantity at this point
s13 Z Brakes on s13
What's up guys! I know this has gone over with many times but I need some help, I would appreciate it and thank you before hand !
I am getting a set of 350z full brake kit ( Calipers, Rotors, E-Brake Assembly ) what ever you name I can get it.
Now what I was wondering is would I need any adapter for mounting the rear E-Brake assembly and or the calipers if I'm using the Rotors off the Z ?
How about the front?
Will I be Ok if I use the caliper and rotors all around ?
Also any suggestions or tips ? Thanks for the help !
SXIIIkali is offline
Old 10-01-2013, 07:59 AM   #2
enkei2k
wrong section for this. this section is for forum related tech support
Ask enkei2k
xquizitditz
enkei2k is offline
Closed Thread
