Okay I haven't had any luck selling it complete so here goes the dreaded partout. Motor had an injector leak and believe to have blew the headgasket. It did not hydro lock and still had good compression when pulled. I have since went to an LS swap so no need to keep storing this beast
ALL PRICING IS OBO AND DOES NOT INCLUDE SHIPPING NO TRADES UNLESS YOU HAVE LS PARTS, T56 or CD009 PAYPAL-BUYER PAYS FEES Text for Pics 269-838-6147 I will upload pics asap Built Head $800.00 BC Valve Springs/Retainers HKS Stage 2 V1 262/272 Cams (Mean AF can send video) JWT Cam Gears (Degreed Properly) ARP Headtsuds Greddy RAS Valve Cover/Gasket/Stock Hardware (2 Cam Cap Bolts Re tapped) Built Short Block $1000.00 CP 9.0.1 Pistons Eagle Rods ARP Main/Rod Bolts S14 Oil Pickup Timing Chain Included No Front Cover/Oil Pump PARTS__________________PARTS Greddy Oil Pan Re-Tapped Drain Bolt With Better Thread Pitch $250.00 Jecs 850CC Injectors(Fresh Flow Test With Papers) $250.00 Greddy Intake W/Iacv SOLD Garrett GT2871RT25 Shaved/Polished Comp ousing Great Shape $800.00 Enthalpy 62ECU 250.00 Megan SR Bottom Mount Mani $50.00 Greddy Remote Oil Filter Complete $175.00 S14 Coolant neck and Braided Turbo Lines $150.00 ISR FPR $120.00 S13 Koyo Radiator In Great Shape $175.00 Spec 6 Puck Unsprung Used But Worked Good $150.00 Fidanza Flywheel Used Will Need Resurfaced if Not Bought W/Clutch $175.00 Coilpacks -$100 Alernator-Make Offer OEM Starter-Make Offer PS Pump No Bracket- SOLD ISR Starter- Make Offer Last edited by SteeleBrothersDrifting_Mike; 07-19-2017 at 08:20 AM.. Reason: Sold some parts |
| 240sx, built, parts, sr20det, turbo |
