This thing is pretty sweet. Not much to say about it, it's clean title and currently tagged. Very strong. The car is bone stock besides a stereo and the tach. The speedometer works, it freaks out when it's in nuteral but other than that it works, has the HUD. STAGE 4 Act clutch, open diff, steelies, stock suspension, etc. But the hard stuff is done. However, the car needs the spacer behind the flywheel for the starter to work. (i have the spacer, look it up). The car starts right up when you roll it. It also needs a new throw out bearing (easy since you'll be in there already). $5000, not very flexible. 6618587027
