![]() Join Date: Jul 2003
Maf Vs. Map
Why is it desirable to omit the MAF for the MAP to take its place? In other words, why is it better for the sensor to sense pressure than for it to measure mass? Is the MAP more reliable and therefore tuning's more accurate? And I'm obviously asking about when you have a standalone. THanks in advance.
MAFS are known to be more reliable because they rarely go lean (unless you push beyond their HP rating). MAPS can go lean if not tuned correctly but pressure it more accurate reference than air flow. I would say that if you dont plan on going big there is no need to go with a MAP.
Scott
IG: @scotheocelot |
Old thread but is there anymore info on this subject? Ive been reading up on this on other sites but not much has been mentioned on here. I would like input from some of you guys, hopefully somebody who is actually running a MAP sensor. I have an AEM EMS and was just curious if converting to a MAP sensor is worth the effort? Im not going for a large amount of power, maybe 350whp with my GT2871.
Im wanting a little more informed response. I want to know what the gains are strickly for an sr20det. Pro's an cons of both of them. Why its better to run one or the other.
I dont want to make my decision because you told me not to do it, I would like to weight out the pro's and con's and decide after gathering the good and bad for both set-ups. I appreciate the response but could you tell me why I should stay with my MAF rather then converting to MAP? |
MAP will give you a little more flexibility in tuning, as the sensor is mounted in the intake manifold. You can vent your bov to atmosphere easily, and boost leaks wont affect the car as much if you have a pipe pop apart. Other than that, when you put the intake on the turbo, you dont have to worry about a maf being so far away from the turbo or anything like that, just put the filter on the pipe and be done with it.
All that sounds great! Which is why Im confused about a lot of people saying dont go with a MAP, keep the MAF. Is that from lack of experience/knowledge or do they know something that others dont know. MAP sounds to me like the better choice as long as Im going with a standalone. I hear its also easier to tune the AEM EMS if you have a MAP. All the pro's seem very good about going with a MAP... Is there any bad side affects?
With map you lose load point resolution once target boost is hit
Whereas maf will still have resolution throughout the rpm band as airflow increases (pressure remains constant at target) Maf is also easier to tune there is no base map and correction map.... just correction It'll run out of the box on a base map much better as well Unless you're maxing out any mafs available to your setup (and you can run 600hp with a z32) there is no sense going to a map based setup IMO And even then you can have custom mafs made to measure pretty extreme amounts of airflow They say the drawback of mafs is a restriction in the intake... True with a stock mafs that bottlenecks... Run an rb25 or z32 and there is no restriction they are 80-90mm just like your inlet pipe I have a map based PFC on one car and mafs based on another so Im familiar with both Just my $.02 |
#10 | |
I guess what Im trying to do is seperate the good/knowledgeable info from BS info. Thanks |
![]() Join Date: Jul 2006
one less important note, but a really good one,
if youre far away from home and pop the intercooler piping right off and have no tools, you can still drive home on map. where as with MAF youre SOL and have to call a buddy etc. especially if youre piping is complex and has the couplers behind body parts etc etc
DODOlogic.ca
#22 |
Make sure if you stay MAF you vent the BOV back to the intake, if not when the BOV opens the ecu has read all that air let out and will dump all the fuel for air thats not there.
#23 |
#24 | |
![]() Join Date: May 2011
Not sure on that one, I have a atmospheric BOV ( GReddy Type R ) and I dont run rich or lean when im under boost from it opening or closes. Does it vary on BOV types ?
#25 | |
And if I remember correctly, MAF is much more user friendly, MAP's require tweaking when you change other things on the motor, whereas MAF's are pretty straight forward. Then again I havent really dealt with any of this so Im kinda just blowing it out my ass ![]() |
#26 | |
There's not really any way around it, if you create a boost leak post-MAF with an atmospheric BOV, the car WILL run rich whenever it opens. The duration and severity of the rich spike depends on a whole multitude of variables (tune, BOV type, BOV spring stiffness, turbo, target boost, intake piping, etc etc), so it's up to you to figure out if it's a big deal on your car. |
#27 | |
after that i went from MAF to MAP with a powerFC, full-race gt30. saved time making intake piping, sometimes ran just a filter right on the turbo. had a greddy manifold and the MAP sensor screwed into the tapped holes on the bottom. couldnt have been easier than this. tuning it by myself too was also a cakewalk.
DODOlogic.ca
#28 | |
You'd have to pick what condition you want to try and tune around... for instance, if you were concerned with getting the car as fast as possible in a straight line and you were convinced that bogging during gear changes was slowing it down, then you would log data while doing WOT runs going through a few gears. Now, I don't know which variables the base fueling map on the Nissan stock ECU is based on, but based on how it works on my WRX it's probably something like RPM vs. Load (calculated based on TPS and MAF). So, you'd figure out the RPM and Load where the BOV opens in your data logs, then take fuel away from that part of the map until you're at the AFR you want to be at under fast shifting, and the car behaves how you want under those conditions. Problem is, the BOV being open has almost nothing to do with RPM vs. Load. During your tuning sessions doing WOT runs on the freeway, the car may behave much better during shifting, but if there's another situation that can cause the engine to be at the same RPM and Load that you just changed the fueling for, but NOT open the BOV, then you're fucked. If you were running 20% rich under shifts, you're now going to run 20% lean if the BOV doesn't open and you hit that cell in the fueling table. I don't know how well I explained that, if it doesn't make any sense then let me know. |
#29 |
Man w/ CTSV & a Car Seat
Both setup up has its pros and cons. I have run rom tunes and piggyback SAFC with Z32 MAFs. I decided to go MAP for the simple reason of not having to worry about getting a bad MAF again. Also, if I have a boost leak or crash the car where the piping are destroyed, I can still drive the car home no problem. The only downside of a MAP is if you have any boost leak, the car wont "let you know" it has a leak. On a MAF setup, if you have a leak, the car will run rich and potentially bog. On a MAP setup, the car will just feel slower.
