Old 05-01-2008, 03:24 PM   #1
turboKA
turboKA is on a distinguished road
S13 clutch problems..help please!!
I just installed brand new clutch, pressure plate, bearing, master and slave cyl. the other day.
The car ran perfectly fine for about two days, then the clutch pedal sank and didn't come back up while transitioning from fourth to fifth.
I looked under the car, and the slave cyl. barely touches the fork when the slave is fully extended.
The fork is pushed all the way back, and the slave's piston keeps popping out as it tries to push the fork.
I haven't pulled the tranny out yet, I'm trying to figure out what the problem is first.
any help/ideas greatly appreciated.
thanks in advance
turboKA is offline   Reply With Quote
Old 05-01-2008, 04:21 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
you might haven bent the fork itself, my friend and i were just talking about a similar scenario but as a common problem for rx-7 guys
Slip Gypsies Blog
not sure if you realize this
Old 05-01-2008, 05:22 PM   #3
nani
nani is making his/her stupidity well-knownnani is making his/her stupidity well-knownnani is making his/her stupidity well-knownnani is making his/her stupidity well-known
throw out bearing might have caught some debris or something and its holding it there. just my .02
nani is offline   Reply With Quote
Old 05-01-2008, 07:53 PM   #4
Sileighty_85
Sileighty_85's Avatar
either that or the Fork Pivoit Ball Broke, Ive seen that a couple if times.
usually only happens when stronger pressure plate are used
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-01-2008, 09:07 PM   #5
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Clutch fork.... pivot... tb... sounds like you'll need to drop the tranny to tell exactly what the problem is.
Old 05-01-2008, 10:22 PM   #6
xblack240x
xblack240x's Avatar
xblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the rough
Send a message via AIM to xblack240x
You're gonna just have to drop the tranny. Probably any of the things mentioned... I agree mostly with the fork pivot ball being broken...
xblack240x is offline   Reply With Quote
Old 05-01-2008, 10:27 PM   #7
ka24delover
ka24delover's Avatar
ka24delover is making his/her stupidity well-knownka24delover is making his/her stupidity well-knownka24delover is making his/her stupidity well-knownka24delover is making his/her stupidity well-knownka24delover is making his/her stupidity well-known
Send a message via Yahoo to ka24delover
ka24delover is offline   Reply With Quote
Old 05-02-2008, 12:44 AM   #8
turboKA
i pulled the boot off around the fork and the ball seems to be fine. the bearing slides back and forth, so i was guessing the fork too... we'll find out this weekend. I just don't have access to a garage and its kinda difficult to drop the tranny anytime of the day/week.
Thanks for all your input.
