#1411 | |
![]() Join Date: Jan 2003
![]() ![]() Feedback Score: 13 reviews
I've been itching to rework my IC setup to recirculate back to the intake, but have the same concerns about pipe length/arrangement from the BOV back to the intake. Can anyone chime in who has a recirculation setup with the BOV on the cold pipe and how it affects drivability compared to venting to atmosphere? |
#1412 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
Correct. MAP systems read pressure, so non reciruyclation won't effect anyhting in regard to driveability. It only measures the total Manifold pressure, so any sort of measured flow makes no difference...where in a MAF it does. Quote:
On a Turbo VR6 car, we actually ran a recirculation tube darn near across the engine bay, and had no issues with how it drove, idled, or worked. I don't think there is much difference, just so long as you do recirculate the air. I've done plenty of hot pipe reciculations as well, and they obviousdly work as well...plus plumbing for them is super easy.
#1413 | |
I guess you would need to size the diameter according to the expected flow having regard to the length so as not to cause a restriction. |
#1414 |
![]() Join Date: May 2008
hey guys just wondering what clutch you guys are running with your setups?
i will be running 2871r 264/272 cams 740cc injectors shooting for 350-375 i've been reading a lot and can't decide what clutch i should go with. i've been looking at either the exedy stage 2 or the spec stage 3 or stage 4. the car is mainly a track car that gets driven on the street every now and then. so it will get abused a lot. with that said what would you recommend?
#1415 |
Trader Rating: (58)
I run a Jim Wolf Z33 Clutch and Flywheel. Works really well, nice easy fully sprung disc to boot!
#1416 |
![]() Join Date: Sep 2005
exedy street disc
on another note...recirc is OVER rated! i have never recirc-d my BOV and never had an issue. my wrx has a recirc on it stock but i removed it and dot have any issues there either. i wouldnt be to worried about recirculating the BOV |
#1417 | |
Trader Rating: (58)
This is not the thread for recirculation discussion, bottom line is on a MAF car it's the proper and only way to fly. Will 1 out of 100 work? Yup. That doesn'tmean it's right. If it really wasn't needed, than the OEM's wouldn't do it...
#1418 |
![]() Join Date: Oct 2004
Don't Run SPEC, rull of thumb around here... Exedy Stage 2 doesn't last long at all... Go with Jim Wolf or the best one probably RPS Max Turbo with a Street Face.... Awesome cluth
Turn and Burn!
#1420 |
Trader Rating: (58)
What sort of torque are you making?
#1422 | |
#1423 |
You know RPS clutchs are rebranded/painted Exedy units? They're the exact same thing.
#1424 |
Im no expert but I think it'll be VERY hard to achieve 400hp on a GT2871r. With all supporting mods, i'd say youd see around 380ish IMO but im no expert like I said
#1425 | |
Trader Rating: (58)
![]() Congratulations. What to they say, a temporary fix is always permament on a car? Runs vs. Runs well. If I had a dollar for every 'car runs good' that I fixed to 'run better' I'd be a millionaire..but then again this is not the discussion for that. The point is, 1 will work...namely due to a high idle, or a cranked IACV or a combination. You wouldn't believe the cars (just search on here) that 'omg wow runs so much better' after they get over their hardon for the FnF sound, and just recirculate it. (or if you have a MAP based system) Again, this isn't the thread for that. Start another. There are a few cars even in this thread that are making 390's and 400. Just goes to show what good parts and good tuning could achieve. Hell even cars at 375 are capable of making the power...all depends on tune and dyno. This is why you'll see a few of us ask for trap speeds...can't deny physics ya know.
#1426 | |
All rebranded exedy's still have a stamped exedy logo, so I am pretty sure its not.... Also RPS Max Turbo Clutches are rated close to 400FTLBS of torque... maybe you can point me to an exedy that holds that, that is NOT a hyper single? Cause its a different diaphram
Turn and Burn!
#1427 | |
Turn and Burn!
#1428 | |
Well now that I think bout it, I'd have to kinda agree. My friends S14 SR made almost 320hp on with 18psi on stock S14 T28, Power FC, 555cc injectors, Greddy FMIC and some other stuff.. Can't remember what else! |
#1429 |
Trader Rating: (58)
320 on a stock t28 is very high! good power though for sure!
#1430 |
![]() Join Date: Aug 2006
![]() ![]() ![]() Feedback Score: 1 reviews
I can't believe a stock T28 putting out 320whp, I haven't seen anyone here in Calgary pushing out that much with that turbo. I'm almost hitting 330whp with my current setup at 14-15psi 92 Octane gas: <- Conservative tune; plenty for me!
GT28RS (small trim) HKS Step 1 256/264 HKS Valve Springs HKS 555 Injectors Apex'i Headgasket 1.1mm HKS F-Con V-Pro hooked up with A/F Knock Amp. Tuned by a legit HKS Dealer... As for Clutch, i'm using the same one as Slider2828. RPS Max Street Series, just love it! Along with the RPS flywheel, that shit looks baller! My whole goal was going for 'response' and not for high horsepower braggin' rights... Steve.
S14 326 whp, 311 tq @ 15 psi HKS F-CON V-PRO
#1431 | |
I agree with you and my goal is the same. I have a 1.1mm but i have 264/264 step 1.... Can you post a dyno graph for me? I just wanna compare....
Turn and Burn!
#1432 |
Hey Slider2828,
I'll have to visit my Tuner and get a print out of the dyno run, however, I do have an older dyno print out when I was using PowerFC. Keep in mind I used to have HKS Step 2 256/264 cams, but I switched them out with HKS Step 1's; My whole purpose was to have a very responsive car, I think CodyACE will agree that a responsive street car is hella more fun to drive Anyways, I'll keep your informed when I get copy of dyno graph, probably just pm it to you.Steve.
#1433 | |
Trader Rating: (58)
I've got personal friends with cars that Iv'e worked on ranging from 900 hp Trans Ams and Supras to nearly 300 whp N/A HOndas...and in the end of the day, while those cars are all fun (a twin turbo trans am is seriously like warp speed, unreal), they are no cars you can realistically drive everyday and enjoy to the point where you can with a niec 350 whp Nissan. Really, the only cars IMO that are equally as fun are guys with Windsor Swapped Mustangs, and guys with bolt on Z06 cars. That's 'good company' to be with. Anything that traps 115-125 is a nice fun street car.
#1435 |
Trader Rating: (58)
320 on a D/D is like 350 or so on a Dynojet...very nice!
#1436 |
Like I was saying in the other thread.... fixed some crappy piping and it should be better now.... but I dunno if I should go with an ISIS Intake... or just leave it cause I want it to have better response and I am on a .86
Turn and Burn!
#1437 | |
they are no cars you can realistically drive everyday and enjoy to the point where you can with a niec 350 whp Nissan. Really, the only cars IMO that are equally as fun are guys with Windsor Swapped Mustangs, and guys with bolt on Z06 cars. That's 'good company' to be with. Anything that traps 115-125 is a nice fun street car. ^ Good point, its so much fun to just get out and drive it! My Setup: Now: MAP Setup Non-Recirc'd Prev: MAF - Recirc'd If you do it, do it properly or don't do it at all, its not about the cool BOV sound, and I don't really see how venting to the atmosphere in a MAF setup will work correctly. |
#1438 | |
#1439 |
Well I am going down to SteveShadows for a tune tomorrow, so I changed it up with Nismo 740s, instead of DW600cc and also cleaned up and shortened my pipes about 1 ft.... we'll see what is the difference... I doubt I am going to up the boost, but I just needed to clean stuff up....
Turn and Burn!
#1440 |
I'll bite....! Ok tuning in general is about compensating for changes, that being said you have to compensate for this change also. Venting BOV to atmosphere. I do know how to make this cool thing function effectively. Meaning no stalling and no running rich during idle.
What does correctly mean? I've seen car idle at 1000 plus rpm is that ok...? for everyone no but it's compensation for something! And I'd like to point out that I recommend recirculating the BPV to almost everyone. If it's a BOV they have and that's what they want, I'll try to make them happy! On a MAFs based car, you have to pay to play.
