NEED HELP. Ka24de s13 idler sprocket info
HELP PLEASE. So this is the idler shaft bolt the holds the idler sprocket on. Well if you look closely the idler shaft bolt isn't directly in the center. It's more tilted up. Is there a bearing or something that should be behind the idler sprocket to keep the bolt and sprocket directly lined up? This is for a KA24DE 240sx.. |
