anyone around north-central NJ with a set of 5-lug wheels i can test fit?
I'm trying to sort out a pulling problem with my car. After spending $500 to fix it... it's not fixed (although the stuff probably needed to be done anyway).
I'm selling the car and can't afford to keep pouring money into it, but i'd like to at least be able to tell the buyer what the issue is, if possible. I've been advised that it's VERY likely to be an issue with the tires at this point - damaged cord or something. So, if any of you guys have a set of 5-lug wheels with tires known to drive straight, not pull or have uneven wear, i would really appreciate if you could let me try them on for just maybe a mile or even less. I don't care if they're stock wheels... snow tires... whatever. I don't care much about offset or anything like that either, it can probably be made to work for such a short ride.
I live in Essex County and would be willing to drive a bit to wherever you are located. And i have a very flexible schedule. Please let me know if any of you guys can help. Thanks.
