Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Group Buys
Group Buys Dedicated Forum for Group Buys.
Closed Thread
Old 12-29-2006, 11:48 AM   #1
CPARKPowertrix
CPARKPowertrix's Avatar
CPARKPowertrix is an unknown quantity at this point
2007 NEW YEAR RPS clutch and flywheel SPECIALS w/ FREE Steel braided clutch line
Our 2007 YEAR’S SUPER SALES and SPECIALS will run for a limited time starting today and ending Tuesday JAN 2nd. Please email your orders to [email protected]. All pricing is without shipping. (Shipping can range from $5.00-20.00 for single item shipping based on weight. Multiple products may be a bit more)
****RPS SPORT STREET CLUTCH****
KA24:
ZILVIA MEMBER PRICING: $265.00 plus FREE STEEL BRAIDED CLUTCH LINE.
List Price: $311.85
SR20:
ZILVIA MEMBER PRICING: $284.00 plus FREE STEEL BRAIDED CLUTCH LINE
List Price: $335.00
Stock to moderate pedal feel. Most ideal for bolt-on performance upgrades (BPU) such as air intake, exhaust system, ignition system, fuel system and adjustable cam gears. Pressure plates are fully re-build able
KA24: Torque Cap: 220 Pressure Increase: +15%
SR20: Torque Cap: 280 Pressure Increase: +17%
****RPS SPORT 6 Puck Sprung Hub Clutch****
KA24:
ZILVIA MEMBER PRICING: $361.00 plus FREE STEEL BRAIDED CLUTCH LINE.
List Price: $425.00
SR20:
List Price: $425.00
Description: Stock to moderate pedal feel. Most ideal for bolt-on performance upgrades (BPU) such as air intake, exhaust system, ignition system, fuel system and adjustable cam gears. Quick engagement, but smooth enough for street use. Pressure plates and discs are fully re-build able
KA24: Torque Cap: 300 Pressure Increase: +15%
SR20: Torque Cap: 340 Pressure Increase: +17%
****RPS MAX Street Clutch****
KA24:
ZILVIA MEMBER PRICING: $380.00 plus FREE STEEL BRAIDED CLUTCH LINE.
List Price: $448.00
SR20:
List Price: $448.00
MAX pressure plates offer 400 to 600 pounds of extra clamping force to hold your biggest power. Pedal feel is stiff to very stiff and engages smooth. RPS is the only clutch company with a U.S. Patent (#5,769,973) on their single diaphragm pressure plate technology. Our unique dual diaphragm technology allows us to create almost any clutch unit with any pressure ranging from stock to double stock in 100 pound increments.
KA24: Torque Cap: 400 Pressure Increase: +50%
SR20: Torque Cap: 475 Pressure Increase: +80%
****RPS MAX 6 Puck Sprung Hub Clutch****
KA24:
ZILVIA MEMBER PRICING: $433.00 plus FREE STEEL BRAIDED CLUTCH LINE.
List Price: $510.00
SR20:
List Price: $510.00
KA24: Torque Cap: 475 Pressure Increase: +50%
SR20: Torque Cap: 550 Pressure Increase: +80%
****THE RPS CYN-R-G Patented FLYWHEEL****
Absolutely the very best flywheel you can buy.
RPS guarantees that all of the segmented wear surfaces are fully replaceable for the life of your car. CYN-R-G Segmented flywheels utilize our patented (6,793,057) "segmented" heat shield system.
Traditional heat shields warp because of the uneven heat produced by a slipping clutch. Just like a car going around in a circle, the outside tires go faster than the inside tires, the clutch disc slides faster around the outside of the flywheel than it does around the inside. The faster moving outside surface gets hotter than the inside surface. Because metal expands more the hotter it gets, the outside of the heat shield expands more than the inside. Traditional heat shields are made of one piece metal rings, so when the outside expands more than the inside, the only thing the shield can do is warp.
The CYN-R-G Segmented heat shields are not connected so they can expand and contract without warping. A warped heat shield causes the clutch to slip, which causes more heat and more warpage.
Our flywheels are typically 10 to 15 lbs. lighter than the factory units which allows up to 20 more HP to get to the wheels!!
FOR SR20DET:
ZILVIA MEMBER PRICING: $425.00
List price $500.00
Description: The last flywheel you will ever have to buy. The patented segmented heat shield design will not warp like other common one piece heat shields. RPS CYN-R-G flywheels are highly engineered with these benefits like dynamically balanced, crushed Heli coil inserts, stepped dowel pins, and over-sized lock-down bolts that are welded to the ring gear for positive retention.
Weight: 11 lbs.
OPTIONAL INSTALLATION KIT:
Also we are now offering the full installation kit which consists of pilot bushing, throw out bearing, alignment tool
Install kit: (pilot bushing, throw out bearing, alignment tool) $29.95 - $39.95 Depending on make and model.
Choosing the Right Clutch the First Time:
First and foremost you need to decide what you plan to do with your vehicle. Are you going to race the car or simply drive it on the street, or maybe both? The big difference h is, if you plan to race the car at ALL it will change the decision on what type of clutch disc you will require. Using a "street' disc for racing (drag or any type of slipping environment) will "glaze" the surface of this OEM type material. A street disc is made of organic material made for long life and smooth engagement. It is not in any way intended for drag racing as it can permanently damage any street disc.
A street disc combined with a high clamp load pressure plate (Max series) will hold good power once fully engaged. This makes the street disc great for road racing and normal driving with high power and also good for high speed freeway runs. Remember what the duty of your clutch CAN be, getting a 2400 lb car moving from a dead stop and spinning the flywheel at 4000 to 8000 RPM and wanting the two to connect. Using a smooth organic material will not going to work for long! Doing this will absolutely glaze the disc or tear it. Once the disc is glazed, it will no longer hold the same power and it will slip.
A 6 (or any #) puck disc is designed for this type of abuse. The 6 puck disc has a variety of different materials in it; which includes ceramic and brass. This material will bite harder and slipping it will not glaze the material, but will accelerate wear. Picture this type of disc as a sticky tire. It will stick and hook much better, but will wear out faster.
The 6 puck disc with the latest materials are lasting about 20K on average. Of course this all depends on your left foot AND if it is properly adjusted! A street disc when not drag raced can last about 40K on average in a high powered Z. The 6 puck material has come a long way over the years and it tends to last much longer now. They also have become much smoother as well. RPS makes the sprung hub 6 puck and it is very street able.
If you plan on doing any drag racing at all we would strongly suggest only a six puck clutch. For the ultimate hardcore drag racers, we ALSO recommend the Max series. The Max does have a slightly heavier pedal feel, but once again it is highly street able.
ORDERING AND PAYMENT DETAILS:
Please email me:
Name
Shipping address (for shipping quote)
Contact Number
Components wanted
Paypal payments:
If using a Credit card through Paypal use [email protected] Please add 2.9% for Paypal fees.
If transferring from Paypal to Paypal account use [email protected] (NOTE: This account will not accept Credit Card Payments.)
Or you can send a money order to:
POWERTRIX
Attn: Charles Park
9450 Mira Mesa Blvd # B 447
San Diego CA 92126
Please inform me if you are sending payment by mail and send it by means that are track able for your own protection. Example: any shipping company that will provide you with a tracking number or delivery confirmation.
Please feel free to call me with any questions you may have.
Charles Park - www.powertrix.com - 619-944-6055
CPARKPowertrix is offline
Old 12-30-2006, 01:43 PM   #2
94cc0rd
94cc0rd's Avatar
94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute
Send a message via AIM to 94cc0rd
can i get a price for the RPS street sport for KA shipped to 92507?
my clutch is dead...
will the sport street clutch be able to take the beating of an occasional drift day... maybe once a month or two?
i'm broke and 95% of my driving is daily driving / spirited street driving...
94cc0rd is offline
Old 12-30-2006, 04:52 PM   #3
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
I used to use the RPS sport 6 puck on my stock KA back in the day and it took the beating of drift events and daily driving really well. It was easy to drive on the street as well. A lot of the guys out at JD use RPS. Never heard one person say anything bad about them.
Nowadays I use the RPS max 6 puck on my 300whp SR and it takes the beating of drift events really well. I only drive my car to track days and back but I can tell you that the pedal is stiff as hell so I wouldn't recomend it for daily driving unless you get a nismo slave to soften things up.
Aaron uses RPS max with street disc.
Lindsay used RPS max with street disc.
Brian uses RPS sport with street disc.
Flybert is offline
Old 12-30-2006, 08:41 PM   #4
94cc0rd
94cc0rd's Avatar
cool... unfortunately, unless you have expediated shipping available for no extra cost, i might have to pick it up from a local shop... my car is becoming a real pain to drive and im scared that my clutch might give out any time...
94cc0rd is offline
Old 12-31-2006, 07:34 PM   #5
808DRFTR
808DRFTR's Avatar
808DRFTR is an unknown quantity at this point
Price for 6puck Max SR20 shipped to 85014 (business)
808 All Day, Livin The HILIFE!
808DRFTR is offline
Old 12-31-2006, 09:33 PM   #6
articdragon192
articdragon192's Avatar
Price for RPS Sport 6 puck and segmented flywheel for a Z32 NA please.
+1 for RPS. I ran one in my Hatch and loved it. I ran a RPS Sport 6 puck and the pedal feel was very close to stock, but man did that thing grip. Held up at the track too.
articdragon192 is offline
Old 01-02-2007, 01:13 PM   #7
94cc0rd
94cc0rd's Avatar
group buy is supposed to end today... has anyone gotten a PM or response?
94cc0rd is offline
Old 01-02-2007, 07:13 PM   #8
CPARKPowertrix
Sorry gentlemen. We'll extend the GB for one more week
Sorry sorry for the late replies. We'll extend the GB for one more week to make sure everyone gets all thier questions answered and quoted pricing. If we have not PMed you or emailed you yet, We will make sure to get all questions and quotes to you by tomorrow morning. Thanks.
Old 01-03-2007, 08:17 AM   #9
Dr. Moreau
Dr. Moreau's Avatar
Dr. Moreau has a spectacular aura aboutDr. Moreau has a spectacular aura aboutDr. Moreau has a spectacular aura aboutDr. Moreau has a spectacular aura aboutDr. Moreau has a spectacular aura aboutDr. Moreau has a spectacular aura about
Send a message via AIM to Dr. Moreau Send a message via MSN to Dr. Moreau Send a message via Yahoo to Dr. Moreau
flywheel looks cool
Squirrel
'91 240SX Hatch
Redtop SR since March 2006
Dr. Moreau is offline
Old 01-05-2007, 02:42 PM   #10
94cc0rd
94cc0rd's Avatar
Cool... My clutch came via fedex today. Thanks!!!
94cc0rd is offline
Old 01-05-2007, 05:50 PM   #11
94cc0rd
94cc0rd's Avatar
Hey Charles, I just stopped by my bank and they told me that I was charged twice by you guys so my balance is negative right now. I left a message for you as well... I just need this fixed so I don't get charged an overdraft fee.
94cc0rd is offline
Closed Thread
