![]() Join Date: Feb 2009
I dropped in a 2871R on my SR and its spooling up just fine, but im getting a bell like ringing from the turbine, the 2871 was brand new and i can hear the ringing thru the intake. Im assuming its the bearings but i dont know if thats bad or not, never heard of this problem before, any ideas?
Thanks, Tee |
AFC #1
![]() Join Date: Oct 2003
Is it ringing all the time or only at certain times(stop,start,idle,rev..)
What is your intake and intercooler piping setup?
It rings while boosting but its in and out and same when i start it up, itll ring for a second or two maybe 3 and then stop wait a few and then start ringing again. I have a FMIC and a HKS intake
Its a bell like if you got a little cat bell or something like that, so ding, ding, ding would probably best suit it.
![]() Join Date: Oct 2004
Wow, is it loud? I get some ball bearing spool down noise, but I never hear it during idle or boost.... What company is your turbo from?
Turn and Burn!
i have the same turbo and i dont get that sound at all. was there any shaft play? you should check that 1st and that should give you a better id3ea of what it may be.
want to be in the 500whp club by the end of next year!!! |
![]() Join Date: May 2008
Does this turbo have an internal wastegate??? I've seen one time a broken spring in the actuator... or one time, my friend had a hks adjustable actuator, and it was so tight that the spring inside the actuator was loose, and ding ding it goes...
#17 |
sounds like your hks actuator is at the lowest setting causing the wastegate to flap back and forth. put a bit more load on the actuator and you should be fine. same shit happened to me.
#19 |
![]() Join Date: Sep 2005
![]() ![]() ![]() Feedback Score: 7 reviews
My 2871r makes this exact same sound, but only at idle. It sounds like it could be bearing noise, but the noise does sound kinda like a bell. I can really hear it good at my air filter while the car idles. My 2871r has about 3000 miles on it boosted at 16-18 psi.
I havent noticed any ill effects associated with the sound though.
#20 | |
#21 |
#22 |
![]() Join Date: Nov 2008
Holy crap! I have been searching and searching for that freaken bell noise forever! I have been under it and on top of the engine bay looking everywhere trying to see what is loose and making that noise! Its kinda irratating! It seemed to me that engine rattle was when it was most present so I thought something was loose. It seems to do it most when its cold. I never thought it would be the turbo. I have my actuator turned down quite a bit so Im going to look into that too.
