FreshColdBeer.com
![]() Join Date: Feb 2008
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
Gost cam by gobiz corp
I may become a distributor for these units, i have one in my car now. i want to see if anyone is interested in them
![]() - 1.3 Megapixel dual cameras - GPS Module - Built in G Sensor - Player for PC Specification | Main Features | Parts Identification | Software | Installation ![]() Dual cameras and built-in mic (1.3 mega pixels) SD Memory Card (Save data / 1GB per 1hour) (internal 2GB / up to 32GB) Built-in GPS (Detect position and speed of vehicle) Play video and audio data (Automatic installation of GOST player) Built-in G-sensor (Shock sensing on 3-axis) Play VGA (24fps / H.264 codec) Night video recording using infrared sensor Updating Firmware (View your driving history on Google Maps) Continuous recording (Set OVERWRITE) Online map (View your driving history on Google Maps) Separated recording (Select to record with both or front view only) Voice Guide (Device gives verbal commands) Manual recording (Use switch to record event at will) Sense intensity of illumination (Automatic adjustment of brightness) Protect recorded events (Select to disallow overwriting important images) Car Battery monitoring (Stops recording to prevent car battery drain) STEP 1Remove the plastic backing from the double-stick mounting tape on the base of the unit. Attach the recorder so that the camera lens is placed behind the review mirror, as shown above. • Apply force on the double-stick tape for 4-5 seconds to ensure that it is firmly attached. STEP 2Insert the SD card into the SD card slot on the side of the product. Plug the power plug into the power jack below the SD card slot. • Insert SD card before plugging in power jack. STEP 3Push the power cord into the opening between the windshield and the roof. If the power cord seems loose, fix it with the provided spacers (in 3 locations). • The cushions cannot be used in all models of automobiles. STEP 4Continue inserting the power cord along the side of the windshield. (Use a thin plastic object such as a credit card if necessary.) If there is no opening, fix the cord with the provided metal clips and double-stick tape (in two locations). • Remove dirt and dust before attaching the tape. • When placing wires on the windshield, be careful not to damage the windshield with the clips. STEP 5Open the door on the front passenger’s side and push the cord into the opening in the vertical direction of the dash board. If this does not work well, try fixing the cord with the provided clips and double-stick tape (in 1 spot). STEP 6Fix the power cord to the edge along the door frame (in 1 spot). STEP 7Lift up the floor mat and place the power cord to the console box underneath it. STEP 8Fix the power cord to the console box using the provided clips and double-stick tape. This is the last step of installation. STEP 9Plug the power plug into the cigarette power socket inside the car. just tell me what you think of it ![]() |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
^ that...
plus...the go pros have the clear cases to help against damage...
PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r
FreshColdBeer.com
Trader Rating: (48)
the gopro only has 1 camera, you gotta buy a 2 of em to get inside the cabin and outside. pluss i am not sure if the go pro has 3 axis g sensor, or gps mapping / speed mapping?
here are some sample videos i found on you tube... weird korean videos YouTube - GOST Actual Footage.mov and another russian video which shows a screenshot of how it is on your comp YouTube - Broadcast Yourself. how much is gopro, these will be around $249 zar, i could you read your whole message, your iphone4 must have a reception problem ) |
![]() Join Date: May 2004
Trader Rating: (26)
Pretty cool that it has a g-sensor; go pro lacks gps, dual camera, g-sensor but will still provide better video quality over the gost camera. an alternative option would be the vholdr contour hd
Contour | Products | Contour HD however, it lacks a g-sensor. |
#11 | |||
![]() Join Date: Jan 2004
i'm pretty sure the gopro/contour are for a completely different use than this one. those are for fun, this is for some big brother shit.
p.s. Quote:
Trader Rating: (26)
Of course they have different uses; Where as the gorbiz seems to just be meant for automotive use. GoPro and Contour have roll cage, window mounts for your racing needs.
Plus they record in 1080P. and GoPro can shoot in 3D as well, if you have two. |
gopro is to shoot video of you racing, to make a fun video to put online and share with people.
this thing is designed to record all the time, to provide video evidence when you get into an accident. they're completely different uses.
