| Polls Post All Polls in Here. |
![]() Join Date: Mar 2009
I'm thinking about purchaseing Enkie RPF1's for my silver 97. I was wondering if any of you where running these and what is your offset and size.
I'm looking for 17's since I can fit a taller tire in the rear. but also wanted to go wide. 10" wide + for the rear. and 8.5 or 9 for the front. I'm also contemplating about purchaseing 50mm wide quarter panels for the car. I like the wider look. Your input if greatly appreciated Fellas/ Galls 50mm 30mm or Pull Stock quarter panels |
You can get away with any rpf1 size on stock fenders:
This is my car with 17x9 +22 with 50mm spacers and 215/45/17 DZ101's on the rear with a massive roll and pull. I also ran the same wheels on an s13 with no issue with no roll or pull. You will be fine depending on tire size and even with 10" wide and 255 you should just need a good roll and a lil camber to be usable.
DRIFTINDY |
![]() Join Date: Jun 2003
Trader Rating: (129)
I'm running 17x10 +18 on all 4 corners on my s13. Roll and very minor pull with -5 degrees in the rear and -4 in the front. With a bigger pull (still not a major pull) you could run less aggressive camber. A lot of S-chassis fans are retarded when it comes to wide rear wheels. Unless u r running bigger than 10j with less than 10et you can get away with a roll/pull and yes I still see ppl with 9j and +20 or more with overfenders. Unnecessary.
I agree that too many people go wide when they don't need to.
I say get 10" +18 and do a heat gun/baseball bat (or fender roller if you've got one, and the time) pull.
Thanks for the Input Fellas I would like to go 10 or wider in the rear with a beefy tire. No less then 295" wide tire. b/c I would like to protect the wheel some with the tire. ![]() I personaly don't like streatched tires ![]() Here is what the car currently looks like |
#11 | |
![]() Join Date: Sep 2002
