Help asap please!
hi i was at my friend's house and right when I was leaving, My left wheel would start making some noises as if its rusty or loose. i got new tires on but when I put it on the knots on hub was loose too so I was going to change it but was wondering if bearing has to do anything with this problem? or rotor? well also my left wheel wiggles little bit. I was testing it after I lifted it and it did. Any ideas? thanks
#2 | |
![]() Join Date: Jun 2007
Built RB25 - RB The World - Vertex Everything @RBVertexRidge |
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
by your description I would think it's your wheel bearing as well.
though since you mention your studs are loose I'd buy new ones to swap out first. if that doesn't fix the problem then get a new hub and reuse the studs.
- Jimmy Wanted: TBD For Sale: TBD |
