#33 |
SM can't run slicks? I should find out for myself but Im lazy and @ work! Shhhhhh
There are lots of wide small slicks, but not DOT approved. Once again, I forget sm rules. |
#34 | |
#36 |
AutoX Junkie
no slicks...only DOT tires
#37 |
from Canada, eh!
![]() Join Date: Sep 2001
Hoosiers and Kumho V710 can be almost considered as slicks..
-> HaLo Race Car: '98 E36 BMW M3 Daily Driver: '08 Fiji Blue Honda Civic Si SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#38 | |
#39 |
from Canada, eh!
Actually, no tires are alike the V710 or the Hoosier A3S04s...
You can try running RA1, A032R. V700, but you'll never be close enough.
#40 | |
#42 |
from Canada, eh!
Size does matter to a certain extent.
If your suspension cannot fully use the grip of your tires, then size does not matter. ![]()
#43 | |
#44 |
Autox Technician
![]() Join Date: Dec 2001
that is 315/35/R17. up front is 275/40/R17. All Hoosier. Before was 245/45/R16 Victoracer. Lots of grip now. Still getting used to it. Tweaking suspension to utilize it.
#45 |
from Canada, eh!
To fully user your tires, I believe custom Ohlins with independant fluid reservoirs might be a nice choice.
I should send the D2s to have them dynoed (at Koni), see how well they do. On thing is for sure, my next setup will be re-valved Konis with custom ground control springs. ![]()
#46 |
Autox Technician
To fully user your bank acccount + credit limit, I believe custom Ohlins with independant fluid reservoirs might be a nice choice.
I'm probably gonna cheap out and get revalved Zeal Super Functions instead.
#47 |
from Canada, eh!
How do the Zeal fare out compared to other coilovers?
#49 |
from Canada, eh!
that's something to explore....
