![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
2003 gs300 bagged on ag wheels $5k firm
2003 lexus*gs300*
143k miles Millennium silver black leather interior $5000 firm located in central california Interior Black glitter shift **** (s)Junction produce front curtains* (s)bellezza rear curtains Exterior Greddy front lip*(broken now still have it if wanted) Admiration side skirts* Oem aristo*window*visors* Roof spoiler 6000k fogs and low beams* Yellow piaa high beam/daytime*running lights Led interior lights Led*reverse lights Leg*license*plate*lights Suspension 326power negative camber rcas on mooglower ball joints* New moog tie rods* Battle version toe arms* Tc sportline rear upper control arms* Bc racing coils (originally 16k front and 18k/ still have all original parts) but are replaced with uas air springs Air suspension (about 4k invested) ¼ inch air line* 3/8 air line used from manifold to tank for faster fill time UAS aerosport bags front and rear* Uas upper billet bag bracket/ top hat* Uas billet lowerbag brackets front/rear* Custom rear top hat extension* Custom rear upper bag bracket* Avs aluminum 5 gallon air tank* (2) 480c viair*compressors* 200psi compressor pressure switch* 80amp*solenoid*replaces the (2) relays forcompressors* Accuair vu4*manifold* Avs 7button switchbox* External*schrader*valve*for releasing/drain (2) smc 3/8 water catchers* (2) smc check valves Dakota digital*gauge with (5)*pressure sensors* All dot approved brass fittings* All dot approved airline used Wheels/tires ( $1600) •*Avant*Garde*m510*bespoke in gloss white* Billet Candy red center caps 19x9.5 +15 19x11 +18 Federal*tires* 225/35/19 front 245/35/19 rear Cons: check engine light on P0420 Needs alignment sometime in the future Needs a muffled hanger Would go through the rear bushings will post more pics upon request*
Helluva deal.. watched this thing price drop for the past few months. doesnt get much better than this folks. Hard enough to find a GS with black interior! GLWS this is tempting
![]() Join Date: Oct 2004
Bump
message sent.
Drift Indy |
