Old 08-05-2010, 03:58 AM   #1
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
interchanging top hats
so i have a set of s13 jic fla 2 coilovers and i have to adapt s14 rear top hats to them, i found a set of cusco top hats, would they be a direct bolt on to the s13 rear coilovers?
supreme_1 is offline   Reply With Quote
Old 08-09-2010, 03:21 AM   #2
supreme_1
Old 08-09-2010, 04:19 AM   #3
Sileighty_85
Sileighty_85's Avatar
S13/S14 use the same front Top Hats
Rears are different
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-09-2010, 04:57 AM   #4
ayuaddict
ayuaddict's Avatar
Yes, JIC and cusco both use 2.5" ID springs so as long as they both have pillowball upper mount of the same inside diameter you will be okay. You should measure them but i would bet they are interchangeable.
Props to you for using S13 rear coilovers on an S14.
Old 08-10-2010, 06:04 PM   #5
supreme_1
kk thx guys, they are going on the rears of the car.
