Brake lights stay on
Yesterday I found out my brake lights stay on after I turn the car and lights off. I can't figure out the issue
Probably the button that lights the tail lights got stuck somehow. It's pretty much like the switch under the hand brake.
The problem is in the s platform i don't know where that switch is. Hope it helps! Sent from my XT910 using Tapatalk 2 |
#4 | |
press on the brake switch under the pedal, if they go off, you just need to adjust it. |
when the little plunger is all the way out theyre off when its depressed the lights are on. check if its depressed a little when your foots off the brake, if so loosen the nut, unplug the connector and adjust the switch back. don't want to adjust it too far, because u want the brake lights to come on without pressing all the way down (just with light pressure on the pedal)
edit* seems you found the problem |
