SOHC-T Coupe Build
Well I finally gave in and decided to post these pics here, they've been posted on a couple of other forums for awhile now, but you'll get the compiled version.
My build list: SOHC motor: T3/T61 Turbo JGS Manifold JGS Wastegate JGS BOV JGS Custom Sheet metal Intake Manifold Emissions removed Espelir JGT500 Exhaust Built Spare Block(awaiting cash flow) Arias Pistons or Wiseco Crower Rods Clevite Bearings PDM Cam or JWT (undecided) SCE Headgasket ARP Headstuds Hybridka.com Solid Lifter Conversion Fuel and Ignition Control: AEM EMS 30-1600 GM 3 Bar Map Sensor 720cc Injectors MSD 6a Ignition MSD Blaster 3 Coil Innovate LC-1 Wideband Drivetrain: Heavy Duty Pressure Plate Custom Kevlar Clutch VLSD C's Short Shifter Suspension: D2 Coilovers 7/5 w/ Pillowball mounts SPL Tension Rods SPL Traction Rods SPL Toe Rods SPL Rear Upper Control Arms Tein Inner/Outer Tie Rods Whiteline Adjustable Sway Bars Boxed/Welded LCA ES Bushing Set to cover parts that the rest doesn't cover ES Subframe Bushings Custom Nismo Power Bar type tension rod bracket New Front Lower Control Arms w/ ES Poly Bushing Interior: Momo Monte Carlo Wheel Sentra B13 or B15 seats(have both, haven't decided which to use) Footwork: 5Zigen FN01R-C 17x8 35 offset w/ 215/45 F 235/45 R Pics of the car in progress: Car itself is a '92 Coupe, that will sport a pignose at it's current state. Car has been thoroughly cleaned and repainted underneath. The outside has not yet been, because it's in good enough condition that it isn't a priority as of yet. Suspension Parts: Diff Cover |
wow looking really nice. awesome suspension set up. engine is looking awesome.
FS/FT 86 Toyota MR2 ~Andy Last edited by s13andy; 08-08-2005 at 07:59 AM.. |
![]() Join Date: Mar 2003
nice pics. that looked like it was an awful lot of work.
^^ true we have the pic thread. i wonder if this falls under the normal classification of car pics though. this is something different and far more interesting then the typical 'car at an angle in a empty parking deck with harsh lighting' pics. |
I was reading through the post locations and couldn't decide where it fit, but didn't want it to get buried amongst 8 million random pics. So move it if one must, but I'd like to be able to continue to add to it. Without other persons pictures involved if at all possible.=)
#8 | |
![]() Join Date: Apr 2002
If he had posted it in the Picture Thread, no one could ask questions except through PM...then the he's be getting a ton of PM's all asking the same thing. Anyway, what kind of power of are expecting out of this thing?
89 S13 hatch/////98 Subaru 2.5RS |
aWingThing.com
Nice stuff! All that effort and then such weak size wheels????
#10 | |
When the built block goes in we're looking for somewhere in the 500-low 600 rwhp range.=) |
I expected complaints about the wheels, they were purchased a year ago previous to the 17x9 +20 being released. They work fine though. I would like run small spacers to squeeze 245's on them though.
Nice!
So this setup will be running on a stock block?
KILL!KILL!KILL!KILL!KILL!KILL!KILL!KILL! |
For now..yes. I have my spare on a stand 1/2 stripped, waiting to go to the machinest. I just can't afford the parts for it right now, since I'm been undertaking the rest of this lately.
This project must be taking you a long ass time. I say that because you have the old version of the SPL RUCA's. How long has that thing been on jackstands? I got the blue RUCA's too. Bought them on here almost 2 years ago when SPL had a GB to promote their stuff. Done 15+ drift events on them as well as the SPL tension rods and they've held up nicely. I like your subframe.
Since your subframe is off, you should trade your subframe spacers for the type that doesn't have a slit in the spacer. |
![]() Join Date: May 2003
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
wow you must have a lot of time and patience...the project is coming along great and i cant wait to see the finished product...keep up the amazing work
#19 |
![]() Join Date: Sep 2003
dope, one hell of a project to do all at once... MAD PROPZZ.......are u going to powdercoat the valve cover?
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
#21 | |
FYI I'm not in the military. Old paintball clothing. |
#24 |
All the rear suspension is installed finally=). As well as the wheels. It's ready to be dropped on the ground with the exception of us breaking 2 jacks in the process. Should be running in the next 2 weeks if all goes well.
Have pics but accidently burned the wrong ones on the cd that I burned. So I'll post those later this weekend. |
#25 |
![]() Join Date: Mar 2004
dude your car is HOT! love the fact that you *and one of the few out there* kept their single cams and went turbo with it. everyone keeps bashing a single but compared to a DE Sr it kicks major ass stil! hell you can get the single to breath just as good as a dual depending on how you set it up.
I found out thru a lot of the old Z tunnerz that if you were to look around hard there are stores about people who have made massive power on their ka24e's back in the day.
#27 |
Eventually I'll wind up with a Nismo 1.5 way clutch LSD. For now though I have to work with what I can afford. Cash is running out and I recently took a hefty pay cut switching jobs. So I'm having to buy parts that I probably wouldn't otherwise buy for some things.=(
