![]() Join Date: Oct 2003
TF★ - What is caster? Stance Camber/Caster plate test results
What is caster? Caster is the angle measured where the steering pivot axis is tilted forward, from vertical.
Increasing positive caster angle adds straight line stability, self centering of the steering, and camber gain. For drifting, added caster is beneficial for its ability to counter steer quickly and for quick transitions. For Grip, straight line stability for high speed, and camber gained turning turn-in can be a big advantage. So you ask, "I know all this stuff, what's the point of this thread?". Good question. There are problems caused by the way the caster angle is changed on 240sx's. Only way to change caster is to use adjustable tension rods, by shortening the TC rods, you pull the wheels forward and effectively changing the caster angle. By pulling the front wheels forward, you have now changed the geometry of the steering rack to the spindle. Theoretically this will increase ackerman and reduce total steering angle, which is not desired effect you want for performance. To test our theory we put a S13 240sx with adjustable caster arms, coilovers(ride height set 2" lower than stock), stock inner and outer tie rods on our alignment system. Our state of the art system can measure "maximum turn angle", "Measured Ackerman" which we will be using for this test. ( I know its not a 240sx, the picture is to show you our alignment system )![]() 1st test - Stance GR+ with standard camber plates, Stance Tension rods, Stock inner and outer tie rods. Ride height was set to 2.5" lower than stock. We set the initial alignment setting to what we typically set most of the s13's with street tires. Caster - 7.1 deg, camber 3.5 deg, toe - 0 . Max turn angle : 34 deg Measured ackerman : 58% 2nd test - Stance GR+ with camber/caster plates. Stance Tension rods, stock inner and outer tie rods. For this test, we adjusted the tension rods to get the tie rods to sit close to 90deg to the spindle, this also centered the wheel in the wheel well. Caster was around 6deg at this setting. We than installed the Stance camber/caster plates and adjusted the caster to 7.1 deg. Camber was set to 3.5 and toe was set to 0. This way we minimize any variables. Max turn angle : 39 deg Measured ackerman : 51% What does this mean? Ackerman geometry was developed for low speed maneuverability. For racecars, less ackerman is desired. Decreased ackerman will result in better initial turn-in response. For high speed racecars, decreased ackerman geometry is used to compensate for the large difference in slip angle between the inner and outer tires while cornering. This can reduce tire temps and increase traction during cornering. Conclusion : Drifting: Caster/Camber plate will increase angle and faster counter steer for transitions. Also reduce the effect of steering overcenter. Increase in 5 degrees of angle with stock inner/outer tie rods, with spacers in conjunction with camber/caster plate, you should be able to gain 8-10 degrees. That's modified knuckle category... ![]() High Speed Grip: Caster/Camber plate will get the benefits of increased caster angle without increasing ackerman. Low speed Auto X : Caster/Camber plate will reduce caster for faster steering and increase ackerman for low speed maneuverability. Stance Camber/Caster plate will +/- around 1.5 to 2 degrees of caster depending on your camber setting. ![]() ![]()
![]() Join Date: Oct 2010
Fantastic writeup guys!
I posted it here: http://forums.613driftwerks.ca/showt...0073#post80073 On our local forum for all the guys who don't make it out to Zilvia, I hope you don't mind ![]() Offtopic, but I have a 1994 R33 Gts25t, can you PM me the pricing for some stance GR+ and the estimated wait time? Cheers! |
No problem!
Check your PM
Thanks for your support!
Measure the ID of the pillowball.
PM me the ID of the pillowball. I will let you know
![]() Join Date: Feb 2007
Question, will a average alignment shop be able to set these for me? or will I have to go to a race shop?
Nagasaki Motors![]() Friends help you move. Real friends help you move bodies. |
#17 |
Well I know the guys at my alignment shop very well. They drive 240's as well, just wondering if there is special equipment needed besides a normal hunters rack.
Nah Judd, a regular rack should be fine. Not like your trying to get a readout of your exact ackerman and steering angle. Just find out how they work and let the tech know how to adjust them. Done and done. I cant wait for my taxes to come in. MMMM goodies!
#19 |
![]() Join Date: Nov 2003
Great Writeup. We will be including camber caster plates with our S-chasis coils now.
www.AutoRnD.com Nardi, Enkei, Stance, AME Master Distributors for USA Check Out Our Facebook! |
#21 |
![]() Join Date: Mar 2003
Ummm... you guys realize that the Stock Tension Rods with their Huge bushing is designed with this in mind already, and by replacing it with rigid Tension rods you are eleminating this movement?
No, I am not saying anyone should revert back to those useless dry rotted, weak stock rods. Stance - Great job putting the factory suspension geometry back in use. TF - Thanks for educating everyone. |
#22 |
"Low speed Auto X : Caster/Camber plate will reduce caster for faster steering and increase ackerman for low speed maneuverability."
Did you mean OR rather than AND? And wouldnt you reccomend the higher ackerman set up for autocross?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: #/f/tech-talk/147301...d-gto-pan.html |
