![]() Join Date: Feb 2008
I need to know how the S14 SR heater hoses are supposed to be routed.
![]() There's a pic and I just need to know if the lower hose under the manifold goes to the upper inlet on the firewall and if the upper hose under the intake manifold goes to the lower inlet on the firewall, or vice versa. |
![]() Join Date: Apr 2004
Fortunately the S14 SR FSM is available in English. Pull up the cooling section and look at how coolant flows to the heater core.
If you want to make sure pull up the FSM for the body and look at the inlet and outlet for the heater core. Match them up with the heater core on the body however you want with adaptors and such. |
| heater, hose, s14, sr20, swap |
