Z32 TT buck at WOT
ok i cant figure this out i have a JDM swaped auto(turbo trans) TT z32 @ 13lbs and when im at WOT easing into or just flooring the pedal the car bucks and rpms drop, it does when boost is at 13lbs but not right away just when the rpms are high, other than that it drives fine, no weird noises, no codes, no leaks boost holds, same power it just cuts itself off, before i had this problem my ECU was governed to 120 i could never go past that, but this is completely different, so any thoughts please!
![]() Join Date: Dec 2006
probably blowing out spark, check plug gaps
i know how bad plugs feel and i have a feeling its not that, my car doesnt backfire or anything plus the buck was major not slight, But in all circumstances i took it for a drive again and now its normal again lol, i think its a bad sensor for some reason so im gonna check the tps/maf, plus when it was acting strange the tranny would shift up down up down only sometimes driving normal at about 20-30 mph, felt like the car was being jerked back n forth making its mind up to go into 2nd or stay in 1st
Check your MAF, TPS sensor, and CAS timing, IF the CAS isn't between 15-17 degrees, it'll buck.
Also, the TT's are notorious to run like crap unless the specified plugs are used, and gapped accordingly. |
