![]() Join Date: Aug 2007
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
s14 header
I just bought it cause the seller said i can use it on my 91 ka24de. Can i use that on a s13 ka24de? Everything line up but there is another line from the s13 which i don't know what it is. It is like the egr line but below the oxygen sensor. Can i just leave it out? Will it affect anything? Sorry search but can't find anything.
thanks |
![]() Join Date: May 2003
The extra line on the stock S13 exhaust manifold is for the AIV/PAIR valve...and should be removed.
You're in GA, with no emissions testing...so ditch it. Remove the metal line, the rubber line, and the box. Cap the hole in your airbox, if you still have the stock airbox. - Brian
www.KA24DEvelopment.com |
hey guys, what happen if i took my stock header off and crank the car and fire come out of there? Also if i step on the gas fire shoot out farther but if it just idle, it's ok. I also took the aiv/pair valve out.
![]() Join Date: Dec 2002
Yes. Quit asking.
You'll have to use the correct EGR pipe, in this case an S13. Was that really so hard to figure out?
Rubber + exhaust = melted pile of goo.
Kid, are you even bothering to use your brain before you ask a question?
#17 |
Oh damn my bad man wasn't thinking bout that just thought of how to hook it up, got so much things going on lately can't think str8. Damn so i think i need the egr line from an s14 then since the header is for the s14.
