Old 11-13-2001, 01:08 PM   #1
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
Send a message via AIM to Grant Send a message via MSN to Grant
I want to buy it, but the guy says theres only 43k mi on it while I have 83k mi on mine, I want the new cluster to read my actual milage? is there anyway i can go about doing that?
Grant is offline   Reply With Quote
Old 11-13-2001, 01:20 PM   #2
Gold240se
Gold240se is an unknown quantity at this point
I'd be careful with messing with the odometer.  Even if your correcting for the better.  I also don't think the numbers come with the guages, I was under the assumption that the actual numbers were attached to the car and not the cluster.  I could be wrong though.
Gold240se is offline   Reply With Quote
Old 11-13-2001, 01:30 PM   #3
vancouvers14
vancouvers14 is an unknown quantity at this point
Send a message via ICQ to vancouvers14
if you just want the white faces, just use those, and you won't have to worry about the miles.  i think you can just change it by hand if you want to change the miles though.  when you take the cluster out, everything is exposed, so it shouldn't be that hard
vancouvers14 is offline   Reply With Quote
Old 11-13-2001, 03:05 PM   #4
nismo270r
nismo270r is an unknown quantity at this point
Send a message via AIM to nismo270r
Once you get the gauge cluster out of the dash, (and yes, the numbers are part of the gauge cluster), there is a way to roll the numbers I believe.  IIRC there is just a dial back there, that would normally turn in accordance to your mileage.  Just be careful not to break anything in there.
nismo270r is offline   Reply With Quote
Old 11-13-2001, 04:56 PM   #5
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
I know you can't roll it backwards, but I don't know about going forwards.  Try asking a dealer (or someone who may have to replace a gauge cluster) b/c they would likely be able to match the mileage.
HippoSleek is offline   Reply With Quote
Old 11-13-2001, 05:08 PM   #6
yenpit
yenpit is an unknown quantity at this point
is it mechanical with a cable OR electronic???
yenpit is offline   Reply With Quote
Old 11-13-2001, 05:10 PM   #7
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
speaking of mileage, a friend and I were talking about this a while ago, how much do you have to do to a car before you can reset the odometer to zero? It must be allowable after a certain amount of modification, because I doubt that restored model t's (just an example) have the original mileage on them....
transient is offline   Reply With Quote
Old 11-13-2001, 06:16 PM   #8
alchemist
alchemist is an unknown quantity at this point
model T's in general are granted an exceeds mechanical limits designation.   They cant hit 100K.  You are most likely going to have a dealer do it for you otherwise you are looking at some trouble.  As for being able to change it to zero........you can do it at anytime, but need to disclose the milage that was on the chassis at the time of the reset.
alchemist is offline   Reply With Quote
Old 11-13-2001, 06:25 PM   #9
transient
transient's Avatar
ahh, I see. So no cars out there actually have the mileage completely reset? I guess it brings up the question of what part of the car the vin number actually belongs to as well... New thread... branched off here
Old 11-13-2001, 06:33 PM   #10
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Just so you know, in models '96 or newer (I believe) if you try and roll the odometer, blue ink will disperse out of nowhere permanently marking the odometer. It's an anti-mileage-fraud thing. My boyfriend told me this, he works at a Nissan dealer. So, I wouldn't mess with it.
S13Grl is offline   Reply With Quote
Old 11-13-2001, 08:07 PM   #11
transient
transient's Avatar
Man, it would be a pain if you hit that accidentally when you were working on something.... *Splat* awwww damnit.
Old 11-13-2001, 10:23 PM   #12
alchemist
they are just playing with you....no ink sprays out.  The newer nissans (non digital dont have it)  My altima didnt have it......think of it this way.....your cluster breaks and you go to nissan for a new one.....it is shipped with mileage of 0000000,  the techs at the shop know how to change the odometer to whatever setting the broken one was at.........how do i know.  I had my cluster replaced twice and I saw the cluster with 0000000 and the real mileage a few minutes later.
Old 11-13-2001, 11:35 PM   #13
transient
transient's Avatar
well, it made for a pretty funny image in my head <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 11-14-2001, 11:32 AM   #14
S13Grl
Married to the Mob
S13Grl's Avatar
This is what I heard from a Nissan Tech Shop, so... they're lying...
And this was in regards to a 240SX. So, Altimas I don't know about.
Old 11-14-2001, 05:01 PM   #15
alchemist
s13 girl, how do you suppose they techs set the mileage on an odometer, &nbsp;there is a way. &nbsp;Do you also believe that if you pull a fire alarm it will spray permanent ink on you so that they can catch you?
Old 11-14-2001, 05:11 PM   #16
KoukiS14
KoukiS14's Avatar
KoukiS14 is an unknown quantity at this point
Send a message via ICQ to KoukiS14 Send a message via AIM to KoukiS14 Send a message via Yahoo to KoukiS14
How u know it doesn't ink the numbers? &nbsp;Seems like a good idea to me... I'm sure as #### not gonna play with my odometer =)
I did try and fix my S13 odo when I traded it, however. . bought it at 107k miles... hit 114,052 miles and stuck right there. . so I just kept driving =) &nbsp;(It was a Canadian car, but the cluster was from a USDM 240sx.. makes me wonder if it was used)... Oh well... &nbsp;it's the thought that counts =)
-Rob
KoukiS14 is offline   Reply With Quote
Old 11-14-2001, 06:35 PM   #17
alchemist
believe me or not, &nbsp;you are placing way to much faith in a mythical ink box......why is it only present in the 240sx? &nbsp;and not the others in the nissan line? &nbsp;S13 girl, your boyfirend is telling you this to scare pepole from commiting a fraudulent act by changing the odometer
Old 11-14-2001, 06:43 PM   #18
S13Grl
Married to the Mob
S13Grl's Avatar
My boyfriend talked to a Nissan Tech in the Nissan store he works in. It's Nissan's way of protecting odometer fraud. Ink will cover the numbers if they are turned by hand (on years '92 and newer, not sure). If your odometer isn't working, and you want it adjusted, they won't be able to do it to match the mileage. Instead, they'll mount a new one in that will say 000000 and your title will thereon read &quot;not actual mileage&quot;.
(Edited by S13Grl at 7:57 pm on Nov. 14, 2001)
Old 11-14-2001, 06:59 PM   #19
S13Grl
Married to the Mob
S13Grl's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from alchemist on 6<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>1 pm on Nov. 14, 2001
s13 girl, how do you suppose they techs set the mileage on an odometer, there is a way. Do you also believe that if you pull a fire alarm it will spray permanent ink on you so that they can catch you?
</td></tr></table><span id='postcolor'>
Call me stupid directly if you need to. Either that or call a Nissan mechanic in your area.
Old 11-14-2001, 08:08 PM   #20
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
I didnt see anything that could poissibly spray any ink out when i pulled out the cluster on my '95 240.
I have heard of some cars that will put scratches in the numbers if they are turned the wrong way with a ratcheting type thing.
And, it is an electronic link to the odometer, so im sure with the right equipment or a wiring diagram and some electrical knowledge it would be real easy to run the motor to turn it to wherever you want.
Greg
ex-95 SE
gfisch is offline   Reply With Quote
Old 11-14-2001, 08:14 PM   #21
BlankFlip
BlankFlip's Avatar
BlankFlip is an unknown quantity at this point
calm down ya'll, nothin' to be mad about <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> . i'm sure somebody can find proof on how this is set up.
BlankFlip is offline   Reply With Quote
Old 11-14-2001, 09:08 PM   #22
alchemist
dont try putting power to it randomly......unless you are working on your EE or have a very good knowledge of complex electrical circuits putting power to it will royally screw it up.....a little birdy told me that one <img src="#/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=';)'>
Old 11-14-2001, 11:22 PM   #23
Grant
so wait, all I have to do is go to the dealer then. I want the 97-98 gauges cuz they aren't ugly ass oval like my 96. I do have an SE so my guages are white. but I want the round/circle gauges.
