Help buying RB25 in or near philly
ok so heres the story i have an s13 with an rb25 s1 purchased from elite jdm few years back by previous owner i did an oil change on it as i worked for infiniti i had new filters laying around in my tool box decided to use 1 since i said "i have filters no need to buy 1" so i put the wrong filter on, while driving filter flew off engine and spun a bearing so i replaced the bearings a week later my engine locked up..
..so this is were i am now i wanted to get opinions from experiences with jdm engine depot and jdm engine zone or others locally due to elite jdm not having any in stock cause i would have definitely bought it from them i will be replacing the folowing: head gasket, all belts, water pump, oil pump, head studs, main studs, rod bolts, tensioners, main bearings, rod bearings, all gaskets, and piston rings.
all help is appreciated
thanks
